| Door locks not working, trunk release and factory security issues....97 Riv | |
atxjax Special
Name : Jax Joined : 2015-01-25 Post Count : 5 Merit : 0
| Subject: Door locks not working, trunk release and factory security issues....97 Riv Mon Jan 26, 2015 10:57 am | |
| Just bought my my Supercharged 97 Riv. Its got 98K on the clock and exterior / interior look perfect.
Got it with no Key Fobs. Previous owner had the ignition resistor bypassed so it starts allt he time now. Imhaving some electrical issues I hope I can get some help with.
First off the power door locks do not work at all. When I got it the 15amp fuse for the door locks under the seat was not installed. When I put a fuse in I hear a click behind in the armrest for the passenger behind the drivers seat. Door locks still do not work.
The trunk release does not work as well. Not sure whats up with that. The gas door work though.
I did notice that there is a cable connector disconnected at the drivers kick panel. 1st connector closest to the kick panel itself. The connector is blue. I assume that has to do with the security. When I hook it up my interior lights work and all but the alarm goes off and I cant get it to turn off unless I disconnect it again. Having no key fob might be the issue.
Can anyone point me in right direction to fix these gremlins? | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Mon Jan 26, 2015 12:36 pm | |
| First thing I would do is look in the door jamb flexible boot. Pull it back and look for broken wires. Very common on this car and can cause a host of problems. Trouble shooting these cars is next to impossible without the Factory Service Manual. With the FSM and a multi meter, you can isolate the problem component or wire. You can get them on E Bay easily. This one is a steal,
http://www.ebay.com/itm/Genuine-GM-1998-Dealership-Service-Repair-Manual-SET-AURORA-RIVIERA-2nd-Ed-/181323360906?pt=Motors_Manuals_Literature&hash=item2a37b6ea8a&vxp=mtr
The Key Fobs are also available but you need the correct one. This is one for the 98 Riviera, GM/UTA 25678792, on E Bay, http://www.ebay.com/itm/GM-KEYLESS-ENTRY-REMOTE-OEM-KEY-FOB-25678792-/331456406333?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d2c57633d&vxp=mtr
http://www.ebay.com/itm/GM-KEYLESS-ENTRY-REMOTE-OEM-KEY-FOB-25678792-/121553616171?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c4d28fd2b&vxp=mtr _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Mon Jan 26, 2015 6:47 pm | |
| Is the plug you're talking about in this picture? If so, what number is it? You might be hearing the relay inside the RFA module kick on when you plug it in. I think I might be able to solve your issue if we can locate the connector you mention..... | |
atxjax Special
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Tue Jan 27, 2015 12:12 am | |
| No its not in the picture. It's a box / module that has two connectors going to it. It is under the dash right by the kick panel. When this connector is unplugged it kills the interior lights and the alarm. | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Tue Jan 27, 2015 9:13 am | |
| - atxjax wrote:
- No its not in the picture. It's a box / module that has two connectors going to it. It is under the dash right by the kick panel. When this connector is unplugged it kills the interior lights and the alarm.
You must be referring to the Lamp Control Module then (#2). The Body Control Module is next to it on the right (#3) | |
atxjax Special
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Tue Jan 27, 2015 3:02 pm | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Wed Jan 28, 2015 9:48 am | |
| So, you plug that in, and the "alarm" just starts going off for no reason? Is this instantaneously, or does it take a minute? Have you tried plugging it in while you're in the car with the doors shut? Have you turned the Ignition to "RUN" after the alarm goes off? That should kill it if the resistor in the column is good. If you can get the alarm to turn off with the key, we can probably figure out what's going on.
You don't need key fobs as long as you have the Ignition Key. Is there an aftermarket alarm/remote start system wired in somewhere? Or is this just a case where the PO had an issue, and decided to ghetto rig it so the car would still run? | |
atxjax Special
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Fri Jan 30, 2015 1:16 pm | |
| The car just has the factory security system. When I plug it in the interior lights all work.....but if I close the door and re-open them the horn beeps for about a minute. Close the door and open it again and it will keep beeping for another minute.
I will try what you suggested about putting car to run with alarm going off to see what happens.
Also with the lights.........when I close the door the lights stay on and will drain the battery. | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Fri Jan 30, 2015 1:36 pm | |
| - atxjax wrote:
- Also with the lights.........when I close the door the lights stay on and will drain the battery.
Hmmm. By chance, is the yellow "DOOR OPEN" warning illuminated on the dash when you close the door (with the car running)? It might be something as simple as the door latch assembly is bad causing the lights to stay on. That might explain why the PO unplugged that module..... | |
atxjax Special
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Fri Jan 30, 2015 3:49 pm | |
| - Abaddon wrote:
Hmmm. By chance, is the yellow "DOOR OPEN" warning illuminated on the dash when you close the door (with the car running)? It might be something as simple as the door latch assembly is bad causing the lights to stay on. That might explain why the PO unplugged that module..... Could be. I'll check. and report back. | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Fri Jan 30, 2015 3:56 pm | |
| - atxjax wrote:
- Could be. I'll check. and report back.
Make sure that module is plugged in before you check. I wouldn't want something that simple to throw us (you) off. | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv Thu Feb 05, 2015 1:06 am | |
| - Abaddon wrote:
Hmmm. By chance, is the yellow "DOOR OPEN" warning illuminated on the dash when you close the door (with the car running)? It might be something as simple as the door latch assembly is bad causing the lights to stay on. That might explain why the PO unplugged that module..... I am pretty sure Abaddon's right on this one (the doorlatch switch is buggered) but also pretty sure that's not the only issue. | |
| Subject: Re: Door locks not working, trunk release and factory security issues....97 Riv | |
