 What kind of belt does a 1997 Buick Riviera none supercharger?
4 posters
washu45
washu45
What kind of belt does a 1997 Buick Riviera none supercharger? Empty
PostSubject: What kind of belt does a 1997 Buick Riviera none supercharger?   What kind of belt does a 1997 Buick Riviera none supercharger? EmptyWed Jan 14, 2015 12:12 am
Hello there everyone I need some help what king of belt does a 1997 Buick Riviera with no supercharger. Also, does any want have a diagram for the belt diagram with the engine and everything. Thank you for the help.
Merit : 149
PostSubject: Re: What kind of belt does a 1997 Buick Riviera none supercharger?   What kind of belt does a 1997 Buick Riviera none supercharger? EmptyWed Jan 14, 2015 7:40 am
This diagram should work.
http://ww2.justanswer.com/uploads/ZZdaryl/2011-02-05_223731_belt.png
You can look up the belt on www.rockauto.com
GOODYEAR Part # 4060940
GATES Part # K060721
DAYCO Part # 5060937
Take your choice.
PostSubject: Re: What kind of belt does a 1997 Buick Riviera none supercharger?   What kind of belt does a 1997 Buick Riviera none supercharger? EmptyWed Jan 14, 2015 9:40 am
The belt for the accessories is the same on the supercharged and non-supercharged motors... you just don't need the supercharger belt wink
Somewhere around is a picture with the belts and pulley numbers on it, but search is failing me at the moment. I was hoping to find it in our Engine FAQ listing...
https://rivperformance.editboard.com/t1585-series-ii-supercharged-faq-listing
Merit : 149
PostSubject: Re: What kind of belt does a 1997 Buick Riviera none supercharger?   What kind of belt does a 1997 Buick Riviera none supercharger? EmptyWed Jan 14, 2015 4:20 pm
Derek, is this the one?
What kind of belt does a 1997 Buick Riviera none supercharger? Pulleys
Merit : 251
PostSubject: Re: What kind of belt does a 1997 Buick Riviera none supercharger?   What kind of belt does a 1997 Buick Riviera none supercharger? EmptyWed Jan 14, 2015 4:39 pm
GM part# 19244953
PostSubject: Re: What kind of belt does a 1997 Buick Riviera none supercharger?   What kind of belt does a 1997 Buick Riviera none supercharger? EmptyWed Jan 14, 2015 8:06 pm
Yup, thanks Larry! I can never find that diagram when I need it!
Subtract the supercharger from that diagram and you'll see basically the routing of the accessory belt on both SC and NA motors.
Crank, A/C, Alternator, PS, Tensioner(flat), WP(flat), Crank.
» For all you 1997 owners found it! 1997 Buick Riviera REAR Lateral Arm's new
» My new 1997 Buick Riviera
» Hello there everyone and here is my 1997 Buick Riviera
» Problems with my 1997 Buick Riviera
» My 1997 Buick Riviera pictures
Riv Performance ::   N/A 3800 Tech :: Series II N/A Engine, Transmission, PCM-
