 1996 Riv Anifreeze Leak
4 posters
BatMobile
BatMobile
1996 Riv Anifreeze Leak  Empty
PostSubject: 1996 Riv Anifreeze Leak    1996 Riv Anifreeze Leak  EmptySun Feb 08, 2015 4:36 pm
Supercharged 1996 Riv out of intake manifold there is a small plastic bypass tube. This has o rings that have been liberally treated with silicone sealant twice but after 6 or 7 months anitfreeze starts to seep. Does anyone know of a permanent fix? Thanks.
PostSubject: Re: 1996 Riv Anifreeze Leak    1996 Riv Anifreeze Leak  EmptySun Feb 08, 2015 4:41 pm
Merit : 149
PostSubject: Re: 1996 Riv Anifreeze Leak    1996 Riv Anifreeze Leak  EmptySun Feb 08, 2015 6:52 pm
http://www.amazon.com/Dorman-47065HP-Elbow-Type-Heater/dp/B00A1A6PT4/ref=au_as_r?ie=UTF8&Make=Buick%7C45&Model=Riviera%7C394&Year=1998%7C1998&n=15684181&newVehicle=1&s=automotive&vehicleId=1&vehicleType=automotive
PostSubject: Re: 1996 Riv Anifreeze Leak    1996 Riv Anifreeze Leak  EmptyMon Feb 09, 2015 10:57 am
Next time you have it out make sure you clean the holes out very very well. Usually later leaks are caused by crud remaining inside the openings preventing the O-rings from making a good seal.
Also, I have had the plastic version break many times, I highly recommend getting the aluminum ones.
BatMobile
BatMobile
PostSubject: Re: 1996 Riv Anifreeze Leak    1996 Riv Anifreeze Leak  EmptySat Mar 07, 2015 4:11 pm
Thanks for your help, everyone!
