 Another no start.
jbeganny
PostSubject: Another no start.   Sun Mar 15, 2015 12:13 pm
96 Riv. No SC. Car has been fine but yesterday I went to the store and when I came out the car would not start. It made some odd noises when I turned the key to start but did not turn over. Waited a minute and it would do nothing when I turned the key. The lights on the dash would not even come on. Played with the locks a bit thinking it was a security issue but two minutes later the locks would not even work. I went home and got a booster pack. I hooked it to the battery and still nothing. No lights on the dash, no noises, no anything. Then I hooked the booster under the hood, it started right up, and off I went. When I got home I put the battery charger on the battery and left it all night.
This morning I tried to start the car and nothing. No lights on the dash, no noises, nothing. I jumped it under the hood and it started right up. After I shut it off....nothing. Help! There seems to be no juice going from the battery to wherever it goes. Does that mean the cables are bad?
Merit : 125
PostSubject: Re: Another no start.   Sun Mar 15, 2015 3:46 pm
Definitely check the cables at the battery - make sure they're tight on the battery posts. I've had had an occasion or two where mine were not tight and I had issues like that.
Merit : 131
PostSubject: Re: Another no start.   Sun Mar 15, 2015 9:58 pm
Could be the battery itself needs to be replaced. disconnect a cable from the battery and measure the voltage. Lo voltage is a symptom of a battery problem, If the battery is measuring less than 12.2 volts or so out-of-circuit you likely have a problem, could be as simple as it's just worn out.
Could be you want to check the underhood positive and negative terminals. Neg is near the starter, on a frame box rail. Problem with it is it corrodes over time, you might have to replace it, I replaced mine with a stainless steel bolt some time ago. Problems with the positive terminal are unlikely unless there was collision damage or some such.
jbeganny
PostSubject: Re: Another no start.   Tue Mar 17, 2015 12:41 pm
Thanks for the two replies. Battery terminals look good and they are tight. Battery tests good. Is there a fuse somewhere between the battery and the ignition switch? Why does it respond when I jump it from the front? Right now the interior lights do not even come on when I open the doors. I am thinking this has to be simple but I am stumped.
jbeganny
PostSubject: Re: Another no start.   Tue Mar 17, 2015 10:46 pm
Today I went to test the battery and as I was doing that the interior lights came on as I was positioning the battery. I then tightened up the cables, which already felt tight, and everything worked the way it should. We will see what happens but for now all seems well. Thanks.
PostSubject: Re: Another no start.   Wed Mar 18, 2015 8:44 am
Is the battery secured to the floor? If not, movement can loosen the connections over time, causing random issues.
jbeganny
PostSubject: Re: Another no start.   Wed Mar 18, 2015 8:01 pm
Yes, it is secured. Took the car to work today and all went well. Took the battery-pack with me just in case. Aaron, may I change the subject here or should I do it in another section? It contains a bit of criticism regarding your merit system. Please let me know. Thanks.
PostSubject: Re: Another no start.   Wed Mar 18, 2015 10:04 pm
Another no start.
