 ABS actively resetting itself while braking (solved:master cylinder seal)
Go to page : Previous  1, 2
PostSubject: Re: ABS actively resetting itself while braking (solved:master cylinder seal)   Sat Jun 20, 2015 11:36 am
Ha! Love it, vivid use of characters there and very clear to the point. THAT seems to make good sense to me. Alright, looks like my evening shall consist of rebuilding the master then. It's a much better option than death, I'll agree with you on that one. lol
Thanks like you wouldn't believe!
Will update after rebuild (hoping this evening before schedule gets hectic for a few days)
PostSubject: Re: ABS actively resetting itself while braking (solved:master cylinder seal)   Sat Jun 20, 2015 2:29 pm
I wouldn't mess around with that either, could be very dangerous.  www.rockauto.com has a Dorman replacement for 34.00.
IFallsRon
PostSubject: Re: ABS actively resetting itself while braking (solved:master cylinder seal)   Sat Jun 20, 2015 8:49 pm
Is there a fuse for the ABS?
PostSubject: Re: ABS actively resetting itself while braking (solved:master cylinder seal)   Sat Jun 20, 2015 9:33 pm
Yep, a 10 amp in the number three position of the fuse box by the door.
And I'll likely just replace the mc considering the price
IFallsRon
PostSubject: Re: ABS actively resetting itself while braking (solved:master cylinder seal)   Sun Jun 21, 2015 8:20 pm
Geez, I'm a dope. It's labeled clear as heck. I need to pull tires and check wires and sensors. Scan is inconclusive as to why the light comes on.
