 Gen V Supercharger Swap
rivieraking
PostSubject: Gen V Supercharger Swap   Wed Jun 24, 2015 1:48 am
I'm interested in doing a swap from my gen 3 to gen 5 supercharger with lower intake on my 1996 Buick Riviera. Are thhere any special modifications for this swap such as shaving of alternator or etc?
PostSubject: Re: Gen V Supercharger Swap   Wed Jun 24, 2015 7:59 am
Hi, welcome to the forum.
Yes, you will need to shave the alternator a bit. It is extremely easy if you have a grinder. You will also need to buy three longer bolts. 120mm, 140mm, and 80mm if I remember correctly. If you intend to use your stock throttle body, you will need to buy an adapter plate.
PostSubject: Re: Gen V Supercharger Swap   Wed Jun 24, 2015 8:58 am
You will also need to rework how the vac lines go because the 96 has the vac controlled tranny. The vac tree on the gen 3 blower is not on the gen 5.
PostSubject: Re: Gen V Supercharger Swap   Wed Jun 24, 2015 1:07 pm
definitely go for the northstar throttle body. I was very happy with difference in throttle and if youre gonna get an adapter plate, might as well get one for the N*.
PostSubject: Re: Gen V Supercharger Swap   Wed Jun 24, 2015 3:54 pm
^agreed. You can find them dirt cheap if you look too.
Merit : 176
PostSubject: Re: Gen V Supercharger Swap   Wed Jun 24, 2015 3:55 pm
Let's not forget that if you go ahead and do all of this, be prepared to drop some coin on a tuner, or someone who can tune it for you.....
rivieraking
PostSubject: Re: Gen V Supercharger Swap   Thu Jun 25, 2015 10:14 am
What weebsite where I can find northstar throttle bodies?
rivieraking
PostSubject: Re: Gen V Supercharger Swap   Thu Jun 25, 2015 10:31 am
What website where I can find northstar throttle bodies?
rivieraking
Merit : 176
PostSubject: Re: Gen V Supercharger Swap   Thu Jun 25, 2015 12:42 pm
http://zzperformance.com/3800/air-intake.html
Link to Northstar install and adapter plates. They don't sell the actual TB anymore like they used to. You can always nab one of a Caddy in the junkyard....
PostSubject: Re: Gen V Supercharger Swap   Thu Jun 25, 2015 1:53 pm
I am pretty sure I was the tipping point that made ZZP stop selling them. And I take pride in that. hi
If you're on Facebook, search for w-body, 3800, gtp, or l67, and you will find several groups dedicated to buying/selling 3800 stuff. There's cool stuff floating around there all the time.
rivieraking
PostSubject: Re: Gen V Supercharger Swap   Fri Jun 26, 2015 1:29 am
Thanks guys! And by the way what year Cadillac to remove throttle body from? I'm planning on going to the junkyard next weekend.
