 blue smoke from exhaust from 96 Riviera
2 posters
rivieraking
blue smoke from exhaust from 96 Riviera Empty
PostSubject: blue smoke from exhaust from 96 Riviera   blue smoke from exhaust from 96 Riviera EmptySun Jun 28, 2015 3:29 am
After 20 to 30 minutes of driving I see blue smoke from exhaust, which indicates burning of oil. PCV valve has been changed. Can anyone tell me the cause of this? Thanks!!!
Merit : 149
PostSubject: Re: blue smoke from exhaust from 96 Riviera   blue smoke from exhaust from 96 Riviera EmptySun Jun 28, 2015 7:19 am
The usual cause is worn valve guides/seals and/or worn rings. If there is too much oil up in the heads, it can make the car smoke. Years ago when I was young and inexperienced, I replaced the valve cover gaskets on my 1972 Skylark 350. I scraped off the old cork gaskets, and missed a few big pieces when cleaning out the heads. The result was blocked drain back holes. Oil was sucked down the guides and the exhaust would smoke blue.
rivieraking
PostSubject: Re: blue smoke from exhaust from 96 Riviera   blue smoke from exhaust from 96 Riviera EmptySun Jun 28, 2015 7:23 am
Wow I never knew that. I was under the impression that the plastic lower intake gaskets are shot and I bought the aluminum ones. They haven't been replaced before and the car has 208,000 mi. I'm thinking about just overhauling the entire engine.
» My Adriatic Blue '95 Riviera
» Short exhaust / side exhaust
» Midnight Blue Pearl 99 Riviera
» Baby Blue 1972 Riviera GS
» Car will not drive white smoke from behind engine and exhust
