| Security Light | |
+814years LARRY70GS BatMobile ibmoses albertj deekster_caddy Rickw KillaKeninaRiv 12 posters |
98RivOwner Member
Name : 98RivOwner Location : Lakesite, TN Joined : 2014-07-19 Post Count : 70 Merit : 6
| Subject: Re: Security Light Mon Jul 06, 2015 4:44 pm | |
| Chitown.,..what were your initial symptoms? | |
chitown_riv98 Fanatic
Name : Ruben Age : 42 Location : Illinois Joined : 2008-03-10 Post Count : 399 Merit : 4
| Subject: Re: Security Light Tue Jul 07, 2015 8:50 am | |
| Yep, it would stay on, go off, not start, start, Start flashing. It was pretty inexpensive. I got a #7 key made and solved my issues. It was like $20 at my local flea market. I must add it was a generic key with a chip not GM. You can bypass it with resistors or I believe an aftermarket alarm would solve it because they bypass the VATS. You can almost look at the chip on the key and notice it being worn or the chip itself gets loose | |
98RivOwner Member
| Subject: Re: Security Light Tue Aug 11, 2015 10:42 am | |
| Update: some of the cheaper Bluetooth scanners won't read bcm code as stated above...Software by Autoenginuity does offer software with a GM module for about $500...must use your own laptop... Anybody have any experience with this setup? | |
98RivOwner Member
| Subject: Re: Security Light Thu Aug 20, 2015 8:49 pm | |
| Abaddon, a coworker had a matco otc code reader with the GM module..We scanned the Riv today...no active code..one historical code..from the icp..it was code 38 VART Data Loss
https://goo.gl/photos/NGDni2AhLs3VuoqA9
Security light behavior has not changed.. Still stays on for about 1-2 minutes then goes out. Still no issues starting etc.
You recognize this code? | |
| Subject: Re: Security Light Fri Aug 21, 2015 7:50 am | |
| - 98RivOwner wrote:
- Abaddon, a coworker had a matco otc code reader with the GM module..We scanned the Riv today...no active code..one historical code..from the icp..it was code 38 VART Data Loss
You recognize this code? It's UART, not VART (LOL vart....). UART is the data line. I'm not quite sure what that scanner is trying to say. That's the problem with aftermarket scanners. They don't or cannot translate manufacturer specific codes. There is no "36" in a trouble code. The UART codes in the Riv are B0037 and B0038 as far as the IPC is concerned. Yes, it's possible that whatever code that scanner is showing is related to your problem (which would actually be B0038 UART A SDL Fault). B0038 is directly related to broken or frayed wire on the comm line. We've seen this code a few times for a bad Ignition Cylinder or something like that, but usually the Security light stays on and doesn't go out. Now, don't go and start replacing ignition parts. It's hard to say at all what's causing your problem. We do know though, that the Security light is directly related to the Ignition Cylinder, the key, and the BCM. Right now, there isn't enough evidence of anything to start replacing stuff. | |
98RivOwner Member
| Subject: Re: Security Light Fri Aug 21, 2015 11:00 am | |
| Sorry about the VART vs UART,..just looked at the photo wrong...coworker was holding scanner. Could a worn key cause this code 38 UART Data Loss? | |
| Subject: Re: Security Light Fri Aug 21, 2015 2:33 pm | |
| - 98RivOwner wrote:
- Sorry about the VART vs UART,..just looked at the photo wrong...coworker was holding scanner.
Could a worn key cause this code 38 UART Data Loss? S'ok. I was more poking fun at the word VART rather than how you referred to it.... A worn key, or more so a worn chip could cause your concern. | |
| Subject: Re: Security Light | |
| Security Light | |
