| Rounded lug nuts | |
IFallsRon Fanatic
Name : R.L. Joined : 2012-11-23 Post Count : 268 Merit : 2
| Subject: Rounded lug nuts Fri Jul 17, 2015 6:37 pm | |
| Got half a tire rotation going but rounded off a stubby lug. First off, WTF is up with the short lugs? I have one or two on each wheel. It's hard to get a good bite with any kind of lug wrench or socket. Research says get an extractor. Probably a good thing for me to have as I've rounded a couple lugs on my Suburban, too. | |
th3fr4nchi5e Addict
| Subject: Re: Rounded lug nuts Fri Jul 17, 2015 6:50 pm | |
| Find a socket you dont care about ruining that is slightly smaller and hammer it on and use an impact gun to try to break it loose. Never used an extractor. Drilling right through the stud is what my dad has always done. Never seen a lugnut round out when using an impact gun though. | |
| Subject: Re: Rounded lug nuts Sat Jul 18, 2015 9:01 am | |
| Get yourself a proper sized deep socket and stop rounding off lugs! 19mm can sometimes be sloppy, although technically it's the correct size. See if a 3/4" socket has a tighter fit. | |
IFallsRon Fanatic
| Subject: Re: Rounded lug nuts Sat Jul 18, 2015 8:57 pm | |
| - deekster_caddy wrote:
- Get yourself a proper sized deep socket and stop rounding off lugs! 19mm can sometimes be sloppy, although technically it's the correct size. See if a 3/4" socket has a tighter fit.
Wow. How about you keep your pussy-ass advice to your self. | |
KnottyEagle Fanatic
Name : Daymon Age : 26 Location : Battle Creek, Michigan Joined : 2014-08-29 Post Count : 284 Merit : 3
| Subject: Re: Rounded lug nuts Sat Jul 18, 2015 9:08 pm | |
Wow. How about you keep your pussy-ass advice to your self. WTF! | |
1997riv Enthusiast
Name : Joined : 2014-11-23 Post Count : 131 Merit : 0
| Subject: Re: Rounded lug nuts Sun Jul 19, 2015 7:48 pm | |
Wow. How about you keep your pussy-ass advice to your self. How about you don't ask questions if you can't understand a little sarcasm. | |
| Subject: Re: Rounded lug nuts Sun Jul 19, 2015 8:15 pm | |
Wow. How about you keep your pussy-ass advice to your self. Were you not asking for advice? - IFallsRon wrote:
- Got half a tire rotation going but rounded off a stubby lug. First off, WTF is up with the short lugs? I have one or two on each wheel. It's hard to get a good bite with any kind of lug wrench or socket. Research says get an extractor. Probably a good thing for me to have as I've rounded a couple lugs on my Suburban, too.
It seems that you were. Although my initial comment had a bit of sarcasm in it, I was just trying to offer a helpful tip and lighten the situation. The exclamation point should have apparently been a "light sarcastic joke" disclaimer. My note about the 19mm socket being loose at times was quite serious and comes from experience. You asked about rounding off lugs, I suggested a reason why it might be happening and a solution. Sorry if you took it the wrong way. The stock "lug wrench" that comes with the spare can have a lot of play in it, I was suggesting something that might help out. If you don't like the way I said it, I apologize. Insulting me doesn't really help the situation. Rereading it, I suppose you were only asking for advice about getting the rounded lug off. Seeing that the post above mine mentioned the best solution I'm aware of without an extractor (hammering on a socket you don't care about), I was still trying to be helpful so you wouldn't continue rounding off lugs in the future. Sorry that you are having a bad day. My understanding of this board was that we try to offer each other help. I offered what I thought was a helpful suggestion. | |
| Subject: Re: Rounded lug nuts Mon Jul 20, 2015 4:39 pm | |
| - IFallsRon wrote:
- First off, WTF is up with the short lugs? I have one or two on each wheel.
This is where someone replaced a cracked lug stud with ones from a local parts counter. Long ones won't fit without taking off the hub, but shorter ones can be inserted from the back with some persuading. "Get yourself a proper sized deep socket and stop rounding off lugs!" - Quote :
- Wow. How about you keep your pussy-ass advice to your self.
Yeah, you're up to your neck and don't want to know what you should've done. But you know he's right - for next time... If it were me, I'd give a set of extractors a try. Irwin makes a set. I don't like to replace lugs on these hubs when I don't need to. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Rounded lug nuts | |
