 GTO brakes
gojo83
PostSubject: GTO brakes   Thu Jul 23, 2015 4:45 pm
Has anyone swapped GTO brakes onto these cars? I have heard they are really similar to fbody brakes and did see that there was a few write ups on the fbody swap but I have a set of gto brakes off the GTO I parted out so if they can be repurposed im all for that.
Merit : 176
PostSubject: Re: GTO brakes   Thu Jul 23, 2015 5:11 pm
I wouldn't even bother trying. The offset of everything is going to be too much to make it work, let alone have the rotors fit. It's not even a GM made car. Bolt sizing and thread patterns are totally different.
Could you do it? I'm sure you could. Anything is possible. Is it worth it compared to the other options? IMO no....
PostSubject: Re: GTO brakes   Thu Jul 23, 2015 5:35 pm
Let me step outside and give this one a try...
Merit : 49
PostSubject: Re: GTO brakes   Thu Jul 23, 2015 5:48 pm
I know the GTO caliper BRACKET will NOT work because the mounting holes are completely different. The caliper itself may fit into the F-body bracket but at that point you might as well go with F-body/C5 calipers.
gojo83
PostSubject: Re: GTO brakes   Mon Aug 03, 2015 2:57 pm
stumbled on a 00 fbody in the local yard with good tails for my TA and brakes and a plastic tank for my TA winning all the way around
GTO brakes
