 Need help with 98 Riv turn signal wiring
austin296
Need help with 98 Riv turn signal wiring Empty
PostSubject: Need help with 98 Riv turn signal wiring   Need help with 98 Riv turn signal wiring EmptySun Oct 11, 2015 7:42 pm
Does anyone have a wiring diagram for the turn signal switch on a 98 riviera? I am using the steering column in another car and I need to know which wires control the turn signals and which is power in.
PostSubject: Re: Need help with 98 Riv turn signal wiring   Need help with 98 Riv turn signal wiring EmptyMon Oct 12, 2015 10:10 am
You're talking about 4 or 5 different schematics for that Multi-Function Switch. There isn't one whole schematic for it. You'd have one for Cruise, Wipers, Turn Signals, etc....
austin296
PostSubject: Re: Need help with 98 Riv turn signal wiring   Need help with 98 Riv turn signal wiring EmptyMon Oct 12, 2015 10:12 am
Yes... I need the wiring diagrams for Cruise Control & Turn Signals.
PostSubject: Re: Need help with 98 Riv turn signal wiring   Need help with 98 Riv turn signal wiring EmptyMon Oct 12, 2015 4:47 pm
Here's everything I can think of off the top of my head. If I missed something, lemme know.
TURN SIGNALS
Need help with 98 Riv turn signal wiring _98_ri10
CORNERING LAMPS
Need help with 98 Riv turn signal wiring _98_ri11
WIPERS
Need help with 98 Riv turn signal wiring _98_ri12
CRUISE
Need help with 98 Riv turn signal wiring _98_ri13
» J Strong Top wiring/Rhino
» Unstable ground signal noise around ant nests
» Shredding his Legacy at every turn
» My turn to be Goofy
» The Double-Hop Signal
