 computer and module question
scoopy03
computer and module question Empty
PostSubject: computer and module question   computer and module question EmptyTue Jul 10, 2007 6:18 pm
im working on putting a 1995 series 1 supercharged 3.8 in my 2001 alero. i was wondering what modules the rivera have and what the numbers on the modules are for each module so i know which ones to grab. i already got the computer and ecm not sure what else i really will need. im thinking about just taking out the wiring harness out of the alero except what i need for the speedometer cluster wires. it seems pretty simple to grab the complete wiring harness and install it in my car except trying to figure out the speedometer and gauge hook up. the 3400 in my alero has to many problems to begin with some no comments about it please : tongue just to keep it simple for the interested coolant problems/overheating problems and needs new suspension good excuse to get by parents to install new engine. tongue tongue tongue
scoopy03
PostSubject: Re: computer and module question   computer and module question EmptySat Jul 14, 2007 2:52 pm
anybody know?
PostSubject: Re: computer and module question   computer and module question EmptyMon Jul 16, 2007 10:27 am
TTT
can any of you swap gurus help this guy out?
computer and module question Dsc_0110
RivMan
PostSubject: Re: computer and module question   computer and module question EmptyMon Jul 16, 2007 3:35 pm
Honestly, you don't want a 3800 series 1. You'd be much better off with a series 2.
As for the PCM, the Riv's PCM is located inside the car, so if you want to use it in your swap, you almost have to re-wire the entire car.
Best bet would be a 3800 series 2 from a GTP, using a GTP harnass / PCM located under the hood.
-Rob
http://www.RivMan.com
scoopy03
PostSubject: Re: computer and module question   computer and module question EmptyMon Jul 16, 2007 6:06 pm
the alero one is in the car too so it doesnt make a difference. anyways i already have the engine and trans complete got it for a deal that i couldnt pass up. series 1 are more all day long here. it was just a simple question of what modules do the 95 rivs have frown im thinking traction control module maybe abs then im not sure. i see like 3 or 4 modules right under the passenger dash/glovebox.
scoopy03
PostSubject: Re: computer and module question   computer and module question EmptyMon Jul 23, 2007 5:43 pm
anybody how do you tell which module is which i already got the ECM its says it clear as day.
97rivman
97rivman
PostSubject: Re: computer and module question   computer and module question EmptyMon Jul 23, 2007 5:54 pm
That should be the only one you need, everything else is for all the power options,security, etc. Ill try and get you the website, but there is a huge list of wiring harnesses, pcm pinouts and a bunch of other stuff, i think some for fiero swaps which is kinda what your gonna be lookin for. Its on my laptop i think so ill post it once i get home.
jhodges
jhodges
PostSubject: Re: computer and module question   computer and module question EmptyWed Jul 25, 2007 1:32 pm
give me an email and I have 2 PDF files that will give you all the wiring information as well as pinouts for the '95 series 1 3800 S/C PCM
scoopy03
PostSubject: Re: computer and module question   computer and module question EmptyWed Jul 25, 2007 3:29 pm
alright
scoopy03
PostSubject: Re: computer and module question   computer and module question EmptySat Aug 04, 2007 1:46 am
well all i need now is the wiring harness.
» Pulley Question
» Spectrum JR Module Improvement
» grip strength advice..ask david horne any question on grip training....
» Level Adjust Question
» Boston Qualifying Question
