 Door hinge pins and bushings
Merit : 62
Door hinge pins and bushings Empty
PostSubject: Door hinge pins and bushings   Door hinge pins and bushings EmptyWed Dec 16, 2015 1:33 pm
Hey everyone,
My driver's side door on my '97 is a little saggy and doesn't quite close all the way as of late. Here is the evidence:
Door hinge pins and bushings DSC06726
Door hinge pins and bushings DSC06727
Wind noise is pretty prevalent now, but luckily there's no water leaks. The door does wiggle up and down quite obviously, though not significantly. I went to the dealer today and they say replacement hardware doesn't exist anymore. Has anyone encountered this issue before on the Rivs? I can't seem to find new pins and bushings anywhere, unless it's something else I need to look for.
Thank you!
-Andrew Z
PostSubject: Re: Door hinge pins and bushings   Door hinge pins and bushings EmptyWed Dec 16, 2015 1:35 pm
That's because there are no pins and bushings. You must buy the ENTIRE hinge assembly, which comes unpainted. You'd have to have it painted, then install it, or have it installed at the body shop.
Merit : 62
PostSubject: Re: Door hinge pins and bushings   Door hinge pins and bushings EmptyWed Dec 16, 2015 1:37 pm
Ha! That's great. I'll look closer at it and see if it's something I can handle, I'm sure it's not TOO bad. I'm not real familiar with the door hardware like that so I didn't know what I was looking at smile . Off to find part numbers...
Merit : 62
...and obviously the guy at the dealer was no help in this regard. Thanks Scott..
PostSubject: Re: Door hinge pins and bushings   Door hinge pins and bushings EmptyWed Dec 16, 2015 1:44 pm
Got ya covered....
UPPER HINGE
#25540145
LOWER HINGE
#16630231
» Cabelas Door Buster Sale ~ Garmin 60CSX $199
» Help with a shower door
» Rear bushings.
» 2 door wooden cupboard for sale - brand new!
» Battery connector pins question
