| Write-Up: Sequential Turn Signals | |
+46matt270avian llamalor2112 bigdave charlieRobinson ZEP RidzRiv NelsonBC12 abaucom robotennis61 gmann3001 LaFlare The Roadmaster ghpcnm denim jonnyb411 Mr.Riviera SCbuick010 Eldo playa GMFreak8 steve s rivman96 BMD R1V13RA Sweepspear Ship 98RIV7777 EASHER Rickw SuperRiv07 deekster_caddy T Riley albertj 96RivSCMI KillaKeninaRiv 99Rivman Shintsu IBx1 palermocorey90 97rivman Natesriv AA SpaceBar 97Riv-Jon turtleman jax95riv 50 posters |
denim Junkie
| Subject: Re: Write-Up: Sequential Turn Signals Sun Sep 11, 2011 6:11 pm | |
| [/quote] Consider getting the electronic replacement flasher - the OE thermal flasher is OK with the stock load but not differently loaded. Tridon EL12 or Standard EFL1. I have yet to see a decent auto parts store that didn't have them in stock. Consider getting the "truck" version that will handle up to 12 bulbs if the store shows it. [/quote]
I looked at the Tridon EL12. It doesn't seem adjustable, which is what the vendor I bought my sequencer from has suggested. I'd like to get a variable that will plug into the stock receptacle. I think that's possible. Can you tell me the blade configuration for the stock unit? I can't find that info or an illustration, without actually going under the dash and dismantling, which I'd like to do as few times as possible. Thanks!
| Subject: Re: Write-Up: Sequential Turn Signals Sun Sep 11, 2011 6:27 pm | |
going under the dash is no big deal, it's obvious how to remove the driverside insulator panel (black panel under dash) once you look at it. A few screws on edge nearest driver and a plastic clip on the firewall. It is a 2-blade flasher. There is no illustration probably because it is a very, very common "heavy duty" flasher used almost since there were blinking turn signals in cars. Neither flasher I suggested is adjustable. If the sequencer mfg recommended some sort of adjustable flasher then you might/should just get that one. Albertj
denim Junkie
| Subject: Re: Write-Up: Sequential Turn Signals Sun Sep 11, 2011 7:09 pm | |
| Thanks! As a mere vassel here, I appreciate your knowledge. I think Grote has a plug-in that will work. Par t#GRO 44891 (NAPA) OR I could just do this | |
The Roadmaster Enthusiast
Name : Carl Alexander Location : Detroit, Michigan Joined : 2011-12-15 Post Count : 128 Merit : 8
| Subject: Re: Write-Up: Sequential Turn Signals Thu Dec 15, 2011 6:27 pm | |
| The supplied lights don't affect your cruise control?? Some of the LED mods cancel your cruise. | |
LaFlare Member
Name : G Joined : 2010-07-14 Post Count : 85 Merit : 2
| Subject: Re: Write-Up: Sequential Turn Signals Sat Jan 28, 2012 2:29 pm | |
| - The Roadmaster wrote:
- The supplied lights don't affect your cruise control?? Some of the LED mods cancel your cruise.
what and when would cause this? i just installed my sequential tail lights and i was told by the vendor that replacing my flashers with electronic ones would be a good idea. so the riv has 2 flashers...? would these be fine and a perfect fit? signal and hazards; http://www.autozone.com/autozone/parts/_/N-5yc1s?checkfit=true&itemIdentifier=6413 http://www.autozone.com/autozone/parts/_/N-9cjef;jsessionid=DB66EBB3DB5F354D50B3BF4772FA56B5.diyprod1-b2c2?itemIdentifier=69839 when i have the hazards on it sometimes doesn't sequence right. outer bulbs don't flash | |
| Subject: Re: Write-Up: Sequential Turn Signals Sat Jan 28, 2012 3:03 pm | |
when i have the hazards on it sometimes doesn't sequence right. outer bulbs don't flash Those seem to be the EL12 cited earlier in the thread. They are not that much $$, just try one. | |
Natesriv Addict
Name : Nate Age : 54 Location : KCMO Joined : 2007-01-18 Post Count : 509 Merit : 16
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 09, 2012 9:33 am | |
| I just bought one, been meaning to do this since before 2009...time flies! Turtleman will be my guru with his great pics & such! pics soon! Oh the webelectronics universal one | |
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 09, 2012 10:47 am | |
Senses a bulb burned out condition with LED's. Some people have had luck implementing a resister in the circuit, i.e., raising the impedance to that of conventional bulbs satisfying the cruise control that the tail lights are working. | |
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 09, 2012 10:50 am | |
| I've used LED tail lamps before without issue. Anyone actually have a problem with a Riviera, or is this just a "some cars do it" kind of rumor? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Thu Mar 15, 2012 12:57 pm | |
| Guys I ordered the set from WebElectric but they said they had a better set...so I actually ordered that. Here's what the guy told me in the email correspondence - Quote :
The STS-1 kit will work if you replace the center sockets as described on that web site. However, for a few dollars more, you should get the STS-3MP kit. It will convert the middle socket to dual level lighting without replacing the socket. In other words, you don't need to drill the tail light housing to install a larger, 3-wire socket in the middle position.
Let me know if you want to change to the STS-3MP. If I don't hear from you by 9:00 EST, I will ship the STS-1 kit. | |
| Subject: Re: Write-Up: Sequential Turn Signals Thu Mar 15, 2012 6:25 pm | |
| Well that's certainly interesting... I wonder what they do - overdrive the 194 somehow to make it brighten up to 3X57 level? If that's the case, I can't help but think the taillight assy is going to be coming off a lot more often to replace bulbs... | |
gmann3001 Fanatic
Name : Glenn W. Peck Age : 50 Location : Orland Park, IL. Joined : 2011-11-16 Post Count : 389 Merit : 9
| Subject: Re: Write-Up: Sequential Turn Signals Thu Mar 15, 2012 10:56 pm | |
| I just did mine last night! IMO changing the socket is the way to go. its not as difficult as it sounds and it really doesn't change any thing from the lens view other than all three lights are on when you break instead if the two outer lights. | |
| Subject: Re: Write-Up: Sequential Turn Signals Thu Mar 15, 2012 11:08 pm | |
| - gmann3001 wrote:
- I just did mine last night! IMO changing the socket is the way to go. its not
as difficult as it sounds and it really doesn't change any thing from the lens view other than all three lights are on when you break instead if the two outer lights. I agree with you... IF, however, the boys at WebElectrics have come up with something that lasts, then they've got a whole lot more applications than they think they do. A bunch of Buicks in the last 40 years have had our 3-tail-bulb/2-outer-brake-light-bulb systems; like my '69 Wildcat/Electra/LeSabre... | |
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 7:58 pm | |
| OKAY!!!!
Installed it today... had to read the instructions carefully...think it through...but once I did the driver's side...the passeger side was a 10 minute job.
Not going to go over the "HOW TO" since it's pretty simple, and is already posted here
The yellow and purple wires are driver's side, while the dark green and brown wires (with a white stripe) are passenger side wires....
I did what Turtleman did in driling a hole in the rear light casing so both units will be fixed in their position(s). The instructions recommend that both units are mounted in such a way that they face down, and with Turtleman's mod, that's what happens.
All in all a very simple mod. The setup I bought comes with zip ties and wire ties and very good instructions. You'll still want to electrical tape it all and zip tie the loose wires to make sure it's all OEM in apperance...
I love it!
Click these links below to see a short video (If I did it right!)
Driver's side Passenger Side Hazards Lock and Unlock
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:01 pm | |
| OH!!!!
The middle lights...the bulb(s) they supply are BIGGER than the bulb which is originally there...so it can handle the voltage ups and downs this unit sends | |
gmann3001 Fanatic
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:12 pm | |
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:15 pm | |
| Thanks, it's a very easy mod, and if it holds up, I highly recommend it for all Riv's | |
gmann3001 Fanatic
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:16 pm | |
| Hears how mine look | |
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:20 pm | |
| Yes, that's the way mine are.
I HIGHLY recommend this mod to all Riv owners. I had mine for roughly $90 and it's an easy thing to do and makes your Riv...your CAR unique!!
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:23 pm | |
| OH!!!! BTW, when I posted these videos...I didn't realize I'd crimped a wire around the driver's side lower light housing...so I had to undo it all, move that wire...and reinstall...
watch those wires gang! | |
ghpcnm Aficionado
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:27 pm | |
| did my video's post alright??? | |
ghpcnm Aficionado
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:32 pm | |
| I would really like to see it in a brighter light setting, but yes it shows up. Great job you did there, Nate. | |
Natesriv Addict
| Subject: Re: Write-Up: Sequential Turn Signals Fri Mar 16, 2012 8:35 pm | |
| I had my neighbor sit in the car and hit the brakes...they do the hazard light sequence once, then stay on..it's really cool.
I also had him turn the lights on and they still work with the sequencing...just brighter.
This mod should be standard fare for all Riv owners on this site...easy and unique | |
| Subject: Re: Write-Up: Sequential Turn Signals Sat Mar 17, 2012 3:39 am | |
| I can see the turn-signals & hazards pretty well in the vids, Nate. Is it a "video thing", or do the center bulbs no longer run with the tail lights?
Also, did you make a note of what number the new bulbs are? | |
| Subject: Re: Write-Up: Sequential Turn Signals | |
