 Lights in door pull handle and in opener itself.
designer1962
PostSubject: Lights in door pull handle and in opener itself.   Thu Jan 14, 2016 8:23 pm
There are miniscule slots in the upper end of the pull handles and in the cove above the actual chrome door pull handle. I remember reading somewhere here that they are lights, but have had no luck finding that thread again. I believe it was a posting telling how to actually change the bulbs.
Does anyone know if there are in fact lights in these locations, and if so, what activates them? Are they controllable by a switch or something?
Thanks for any information you might have.
PostSubject: Re: Lights in door pull handle and in opener itself.   Thu Jan 14, 2016 8:47 pm
You can look through this thread and find the answers you are looking for.
http://rivperformance.editboard.com/t393-faq-interior-lighting-questions-dash-guage-color#3478
 I used these bulbs to fix mine.
https://www.radioshack.com/search?q=2721092
PostSubject: Re: Lights in door pull handle and in opener itself.   Thu Jan 14, 2016 8:49 pm
They are always on when the headlights are on. I believe you need remove the door panel to replace them. Both were burned out when I got my car, so if they dont light up you might just have to clean the contacts or replace them.
designer1962
PostSubject: Re: Lights in door pull handle and in opener itself.   Thu Jan 14, 2016 9:33 pm
Hey thanks guys. That's exactly the lights I was wondering about. I think I've only driven my car once or twice after dark, so I don't know if they work or not. I'll have to go out and have a look.
Merit : 179
PostSubject: Re: Lights in door pull handle and in opener itself.   Fri Jan 15, 2016 10:50 am
I've got probably 8 LEDS with connectors that I took that the last time I went to the junkyard.
We're talking about the little LED clear lights with the green and black wires? The ones that shine through the tiny hole in the inside door handle?
» Cabelas Door Buster Sale ~ Garmin 60CSX $199
» Pull - Pull Control Cables
» HID lights
» What have you done to your SidexSide this week?
» Pull ups - positive or negative?
