 fuel door trunk release
MarkoRv
PostSubject: fuel door trunk release   Thu Jan 21, 2016 6:50 pm
I've noticed I don't have one in the trunk. Is there any way of tracing where the string was or getting a new one if it has been ripped?
PostSubject: Re: fuel door trunk release   Thu Jan 21, 2016 8:39 pm
If the lining has been taken out and the cable wasn't fed back through its slot it could just be behind the lining. If you have already looked there I'm not sure?
If you don't get a good answer I can take a look and see what I can find out.
MarkoRv
PostSubject: Re: fuel door trunk release   Thu Jan 21, 2016 11:00 pm
Thank you! I will check tomorrow morning, i removed it just a bit didn't spot anything but I'm not really sure where exactly to look
Merit : 62
PostSubject: Re: fuel door trunk release   Fri Jan 22, 2016 8:17 am
Yeah if it is behind the lining/carpeting, it will be buried a little bit. It should be back there somewhere! smile
MarkoRv
PostSubject: Re: fuel door trunk release   Wed Jan 27, 2016 9:44 pm
Thanks guys! It was stuck way way inside down behind the lining but I've found it.
Merit : 62
PostSubject: Re: fuel door trunk release   Wed Jan 27, 2016 9:46 pm
Awesome. It's great when it's the simple things!
MarkoRv
PostSubject: Re: fuel door trunk release   Thu Jan 28, 2016 4:20 pm
lol i know right
PostSubject: Re: fuel door trunk release   Thu Jan 28, 2016 7:11 pm
MarkoRv wrote:
lol i know right
I tried to post pics of where it might be laying behind the lining but couldn't get them to post right?!?
Glad you were able to find it
MarkoRv
PostSubject: Re: fuel door trunk release   Thu Jan 28, 2016 7:23 pm
99Rivman wrote:
MarkoRv wrote:
lol i know right
thanks so much! yeah I went digging and dug it out. The first Riv I had the release didn't work so I had to go to the trunk every refuel, i guess i got freaked out when I didn't see it since I know the release can break down and then this is a life saver
Rivit
Merit : 21
PostSubject: Re: fuel door trunk release   Wed Feb 03, 2016 2:04 pm
Use of a credit card or plasticized card of any kind, handy when detailing or when in a pinch without having to open the trunk for release.
PostSubject: Re: fuel door trunk release   Wed Feb 03, 2016 3:28 pm
lecture Who knew?
Mikel
PostSubject: Re: fuel door trunk release   Tue Nov 29, 2016 7:49 pm
How do I get to the door actuator itself? From the trunk?
Thanks.
Merit : 108
PostSubject: Re: fuel door trunk release   Wed Nov 30, 2016 8:09 am
Thanks.
Yes, open the trunk and pull the liner away a bit. You will see a cable with a black tag that says fuel door release.
