 Rear passenger trim removal
unteir
unteir
Rear passenger trim removal Empty
PostSubject: Rear passenger trim removal   Rear passenger trim removal EmptyWed Mar 09, 2016 9:21 am
Can anyone give me some tips on how to remove the interior rear passenger trim?
PostSubject: Re: Rear passenger trim removal   Rear passenger trim removal EmptyTue Mar 15, 2016 5:30 pm
I see no replies yet? sleep
It has been a while since I did it but I know the seats have to come out first. Then the threshold panel below the door has to come out, remove the trim piece on top and then it is screwed into the rocker panel. The lower side panels are held in with a couple of pretty sturdy push pins.
How much of it are you looking to remove?
The sail panels are held in with a couple more push pins, you do have to be careful with them, they will get damaged trying to remove them if you are not careful. The package tray has a couple of push pins behind the back of the seat back, and then I am pretty sure it just kind of slides out.
Let me know if you need more, I can take a look and see what I can find out.
Hope this helps,
unteir
unteir
PostSubject: Re: Rear passenger trim removal   Rear passenger trim removal EmptyTue Mar 15, 2016 6:12 pm
I'm trying to get behind that trim piece to hammer out a dent that's on that quarter panel. Seems like a PITA to remove that piece. Was thinking of using a dent puller but not sure about the results ID get.
» Rhino rear sway bar removal
» RZR-S Rear Sway Bar
» Rear sway bar removal-has anyone done this?
» Rhino Rear Brake?????
» Rhino Rear Brake AWFUL Noise -- Normal??
