al_roethlisberger Junkie
| Subject: CASE relearn necessary or even possible on 95 SC? Fri Apr 06, 2018 11:15 pm | |
| I'm chasing some problems, one of which is the P0341 camshaft sensor DTC, and through many of the threads it is mentioned that a "CASE learn" or "CASE relearn" may be required if one changes the crank or camshaft sensors, or PCM.
I was wondering if a "CASE learn" was even possible for the 95 SC?
Thanks, Al
| Subject: Re: CASE relearn necessary or even possible on 95 SC? Tue Apr 10, 2018 12:47 pm | |
| Subject: Re: CASE relearn necessary or even possible on 95 SC? Fri Apr 13, 2018 5:53 pm | |
| Yep, am running down the wiring issue for the CAM sensor.
Just was wondering if any relearning was needed. I've already changed the PCM and swapped over the original ROMs a few years ago, and it never quite ran as good again. So just wondered if the CASE learn/relearn was even applicable to a 95 Series 1 SC.
Al | |
| Subject: Re: CASE relearn necessary or even possible on 95 SC? Sat Apr 14, 2018 3:29 pm | |
| - al_roethlisberger wrote:
- Yep, am running down the wiring issue for the CAM sensor.
Al Let's ask Abaddon (hint hint) | |
| Subject: Re: CASE relearn necessary or even possible on 95 SC? | |
