 95 Riviera, Noise from Right Front
tloukaitis
PostSubject: 95 Riviera, Noise from Right Front   Thu Apr 07, 2016 2:30 am
Sounds like a wheel bearing, but I've replaced it (with a Timken), replaced CV Shaft, switched tires around, no difference. Turn left; noise. Turn right; no noise. Notice it more at low speeds than high. Could it be rotor or caliper?
Merit : 135
PostSubject: Re: 95 Riviera, Noise from Right Front   Thu Apr 07, 2016 10:08 am
Can you record it and post a sound file?
Inspect your brakes.
tloukaitis
PostSubject: Re: 95 Riviera, Noise from Right Front   Thu Apr 07, 2016 11:19 am
The brakes are fine. But, if it were brakes, why wouldn't the sound be continuous, not just on a left turn? There's too much other noise going on to get a good recording of the specific sound.
Merit : 179
PostSubject: Re: 95 Riviera, Noise from Right Front   Thu Apr 07, 2016 11:24 am
Because the rotor assembly moves when you turn, and puts "pressure" on the opposing brake pad. It's the exact same concept as a hub.
Inspect your brakes. More importantly, inspect that little shield that hangs down behind the lower ball joint. I'm willing to bet it's touching the rotor.
Merit : 110
PostSubject: Re: 95 Riviera, Noise from Right Front   Thu Apr 07, 2016 3:49 pm
http://rivperformance.editboard.com/t1580-steering-shudder-pump-or-rack-noise?highlight=steering+hose+tsb
Steering - Vibration, Shudder, or Moan Noise
File In Section: 02 - Steering Bulletin
No.: 99-02-32-007A
Date: February, 2001
TECHNICAL
Subject:
Steering Vibration/Shudder/Moan During Parking Maneuvers on Dry Pavement (Install Power Steering Pressure (Inlet) and/or Return (Outlet) Hose Assembly)
Models:
1995-99 Buick Riviera
1997-2001 Buick Park Avenue, Ultra
2000-2001 Buick LeSabre
2000-2001 Pontiac Bonneville
This bulletin is being revised to add the 2001 model year and to update the parts information. Please discard Corporate Bulletin Number 99-02-32-007 (Section 2 - Steering)
Condition
Some customers may comment on a steering vibration, shudder or moan noise when steering during parking maneuvers on dry pavement.
Correction
Install a new power steering pressure (inlet) hose assembly on the following vehicles:
^ 1995-98 Buick Riviera
^ 1997-98 Buick Park Avenue and Ultra
Install a new power steering pressure (inlet) and return (outlet) hose assembly on the following vehicles:
^ 1999 Buick Riviera
^ 1999-2001 Buick Park Avenue and Ultra
^ 2000-2001 Buick LeSabre
^ 2000-2001 Pontiac Bonneville Diagnosis
tloukaitis
PostSubject: Re: 95 Riviera, Noise from Right Front   Sun Apr 17, 2016 11:29 pm
Ended up being a bad bearing on the left side, not right, even though the noise sounded like it was coming from the right. Thanks.
Merit : 135
PostSubject: Re: 95 Riviera, Noise from Right Front   Tue Apr 19, 2016 12:41 pm
thanks for posting, difficult to do remote diagnosis.
» front end noise on 2008 RZR
» rzr deluxe front brushguard for sale
» rzr front diff. rebuild
» Polaris Rzr Deluxe front Brushguard for sale
» Prop shaft trouble on 2010 rzr s
