 IAT Sensor
moestippich
moestippich
IAT Sensor  Empty
PostSubject: IAT Sensor    IAT Sensor  EmptyTue Apr 19, 2016 8:43 pm
I installed a cone air filter with the tubing from a GTP's L67. I had t9 extend the wires for the IAT sensor plug in order for it to reach the place where the GTP has its sensor located within an inch of the throttle body. Shortly after installation I started getting a p0113 (IAT sensor reading high) Should I relocate the sensor farther down the tubing closer to the filter, or do I need to check the wiring splices?
IAT Sensor
» FAQ: P0341 Camshaft Position Sensor (Cam Sensor / Timing Chain)
» MAF sensor and crankshaft sensor
» WB O2 Sensor
» FAQ: O2 (Oxygen) Sensor Information
