 IAT Sensor
moestippich
PostSubject: IAT Sensor    Tue Apr 19, 2016 8:43 pm
I installed a cone air filter with the tubing from a GTP's L67. I had t9 extend the wires for the IAT sensor plug in order for it to reach the place where the GTP has its sensor located within an inch of the throttle body. Shortly after installation I started getting a p0113 (IAT sensor reading high) Should I relocate the sensor farther down the tubing closer to the filter, or do I need to check the wiring splices?
IAT Sensor
» 85 K100 fuel sensor
» Rear Wheel Speed Sensor
» WTB: S14 240sx speed sensor
» 02 Sensor bypass
» coolant level sensor removal??
