 Front end fun
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Front end fun   Front end fun EmptyTue Apr 26, 2016 4:43 pm
Soooo, just got four new tires, pads, rotors (had to find that little star end to remove the calipers) and alignment. Well, turns out they cannot align the front left wheel, they cannot adjust the camber/castor at all. They couldn't tell me why, just they couldn't. Now this is from Town Fair Tire. When driving, it pulls ever so slightly to the right with no hands on the wheel. When I turn left it makes a slight squeak intermittently and quickly two or three times, and when I turn left I hear one or two soft clunks. Just curious as to whats up and how can I get it to adjust for alignment???
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue Apr 26, 2016 4:52 pm
Alignment doesn't cause squeaks or clunks. If something is making noise, it needs to be addressed separately.
As for alignment, camber and caster cannot be adjusted on the Riv, no. However, you can install an eccentric bolt into the upper strut bolt position and create adjustable camber. Caster would have to be adjusted by moving the entire strut around at the mount, which is fixed.
You have before and after spec sheet of the alignment?
Pulling to the right a hair is normal if you consider the degree of road crown.
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue Apr 26, 2016 6:28 pm
Hey Abbadon, is it true or not true that if there is no frame or body pan damage you get the Riv back into alignment with new factory springs and new control arms? (and 0-degrees toe) Please comment
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue Apr 26, 2016 7:25 pm
Front end fun 20160410
Front end fun 20160411
Bottom is before, top is after.
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue Apr 26, 2016 7:28 pm
The castor is what is really wonky, so I'm very interested if doing the control arm might fix this.
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyWed Apr 27, 2016 8:41 am
Considering nothing is bent, one could lose a lot of angle with worn out bushings or sagging springs. If anything, the LCA would correct a caster concern far more than a spring would. A saggy spring would affect the camber (which in turn affects toe).
Trevor, that alignment is awful. No wonder the car feels like it goes to the right. They left it with negative toe on the RF, and positive toe on the LF. This put the steering wheel "centered" to the left, causing a "pull" to the right. It's quite minor, though. We're talking a 5/100ths of a degree difference.....I'd be able to tell. Plus, a car will pull to the side with the least amount of caster. In your case, the right. One degree isn't all that much of a difference, but pair it together with negative toe, and negative camber on the LF pushing the car to the right....it's just all wrong headbutt
I'm willing to bet that if you had an eccentric cam bolt installed (or make the upper strut hole bigger), you could definitely get the camber back to somewhat normal, and the caster would follow suit. However, judging by the difference in camber between sides, I would suspect that something in the LF is bent or worn out. All it takes is one good hole to bend a strut. Even the slightest bend can toss an alignment off a ton. The most MAX negative camber I could even get out of my Riv was -.5* without making the holes bigger. It was physically impossible on a GM strut. That being said, most aftermarket struts already have an oblong hole on them. You don't even need an adjustable bolt. All one has to do is raise the front end off the ground and loosen the strut bolts to adjust the camber. Lookin at that printout, that shop has a decent Hunter machine, so there are no excuses if this is the case.
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyThu Apr 28, 2016 10:27 pm
I think I was able to get just under -2* with eccentric bolts. That being said, with things being that far out I would almost put money on something being bent. Does the wheel wobble at all when jacked up? Grab it at 9 and 3, wiggle back and forth. Same deal with 12 and 6.
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyFri Apr 29, 2016 11:08 pm
I'll give it a look when I'm over this horrid flu, hopefully this weekend or early next week.
Merit : 64
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptySat Apr 30, 2016 9:16 pm
speaking of horrid, you should resize and invert your signature pic wink
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptySun May 01, 2016 3:40 am
" Asgard"
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyMon May 02, 2016 10:22 am
And mess with perfection???? bonk
Merit : 122
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyMon May 02, 2016 11:52 am
http://rivperformance.editboard.com/t716-signatures-new-members-please-read
Pics are cool, but keep the size within reason. Currently, we ask that you keep sig pics to a maximum height of 150 pixels, and a max width of 720 pixels. This keeps the page from looking cluttered, allowing topics to flow more smoothly. If you have questions or need help resizing your sig, please ask the admin.
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyMon May 02, 2016 1:48 pm
Fixed, now back to the topic please.
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyMon May 02, 2016 10:51 pm
You can't replace the bushings in the control arms, so if they are old enough you have to replace them anyway whether or not that fixes the instant problem because the rubber (in the one bushing) gives out (the other bushing IIRC is nylon, someone check me on this).
JR3800
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyMon May 02, 2016 11:45 pm
On my 98 one is nylon the other is rubber, er whats left of the rubber after 16 years of salt
Merit : 122
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue May 03, 2016 9:17 am
He has a 95. He can replace the bushings. But it needs a press.
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue May 03, 2016 10:03 am
Can be done with a Ball Joint Press. I do them all the time without taking the control arm off the car. Just leave it attached by the ball joint. I use an impact gun, so doing it in the driveway with hand tools might be nearly impossible.
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue May 03, 2016 11:04 am
Lemme scrape the egg off my face... dude you ought to replace those bushings every so many years... why didnt we think of this earlier... for me, I have to replace the arms, I will be due for them in 2-3 years.
Trevorusn
Trevorusn
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyTue May 03, 2016 11:34 am
This is all extremely helpful, good to know the bushings for my 95 are seperate, but it brings up another question I was hoping didn't exist...what is unique front end wise on 95s from the rest of the lineup?? Struts, tie rods, bearings all the same??
Front end fun Empty
PostSubject: Re: Front end fun   Front end fun EmptyWed May 04, 2016 2:16 am
"what is unique front end wise" The whole kit and kaboodle,pal
Front end fun Empty
Front end fun
» rzr deluxe front brushguard for sale
» rzr front diff. rebuild
» Polaris Rzr Deluxe front Brushguard for sale
» Rzr front diff parts
» Polaris Deluxe front brushguard
