 Rough idle after hot restart (series l SC)
SpiralArchitect
Rough idle after hot restart (series l SC) Empty
PostSubject: Rough idle after hot restart (series l SC)   Rough idle after hot restart (series l SC) EmptyTue May 17, 2016 3:03 pm
Hi gang,
I have a 95' Riv that typically runs great, but recently when I start the engine when hot (like after stopping to fuel up), the engine idles very rough, best way to describe it is "chugging", after a few seconds it will smooth out to a high idle then settle into a normal idle, when this happens the check engine light comes on and stays on till next restart, engine starts and idles fine every time when cold.
I have a very nice Bosch code reader, but as most of you know, the 95' is a crossover year (OBD-l computer with an OBD-ll interface) so I can't download the codes, and the only place locally that can read the codes charges $89.00 to do it, so I'm hoping someone here has some ideas.
I have recently replaced the TPS, fuel filter, and plugs & wires, any thoughts would be appreciated....thanks!
sloshua
sloshua
PostSubject: Re: Rough idle after hot restart (series l SC)   Rough idle after hot restart (series l SC) EmptySun May 29, 2016 5:21 pm
clean the mass air flo sensor check all vac lines.
» Rough noise
» Lucas Oil Off Road Racing Series Short Course---USTREAM TV Live
» Rough Stuff tempest for sale - SOLD
