 engine light on
MarkoRv
PostSubject: engine light on   Mon May 23, 2016 4:21 pm
I washed the car and put gas in it right after, got home and parked it then headed out 20 mins later and the engine light went on when i started the car. The only reason I can find is that I put different gas (93 from esso instead of the usual 94 from petrocanada) but could that really be an issue? I sanded the gas tank opening had a bit of a rust, thought maybe it is not sealed (gas cap is 2 months old) but the light is still on.
  The cabin fuel tank release button stopped working as well, all in the same day, could it be that? I can still open it from the trunk
it is a 96 supercharged
Merit : 133
PostSubject: Re: engine light on   Thu May 26, 2016 5:58 am
Suggest you either buy an OBD II scanner or go someplace (an auto parts store) and have the codes read.
The gas cap could be the problem, I am on my 5th. Some dealers have a gadget to test them. Not sure why they go bad but a parts guy told me the gaskets get stiff and start to leak air. Also said that Stant had had issues with those gaskets that of late seems to be fixed.
MarkoRv
PostSubject: Re: engine light on   Sun May 29, 2016 1:30 pm
I put the 94 I usually put in the car and the light dissapeared, it was the only time I put 93 cus i was at esso and the car was empty didn't wanna risk it. really weird though, 93vs94 it's almost the same
engine light on
