 Asking the pros before I commit (front coil springs)
Wolfmaster579
Wolfmaster579
Asking the pros before I commit (front coil springs) Empty
PostSubject: Asking the pros before I commit (front coil springs)   Asking the pros before I commit (front coil springs) EmptyMon Jun 13, 2016 1:39 pm
Been trying for a while to get replacement coil springs for the front of my 88 T-type Riv.
Finally called the dealer, they said there are 3 weight/load codes FLN, FLR, and JYL. Obviously, I am not sure nor can I tell what mine are (ID tags on the springs are long gone), but part number 22197295 are the only springs available and they're fairly certain these will work for my vehicle.
Does anyone have any insight to this? I can get them from GMpartsdirect for $80 a piece.
PostSubject: Re: Asking the pros before I commit (front coil springs)   Asking the pros before I commit (front coil springs) EmptyMon Jun 13, 2016 1:51 pm
The springs will more than likely work no problem, as all the springs listed would be the same dimensions, just with different spring rates.
FLN, FLR, and JYL are probably the RPO code for which suspension your car has. It would be listed on the RPO sticker which is probably in the trunk somewhere.
If there's only one spring available, I guess it really doesn't matter which suspension your car originally had.
Wolfmaster579
Wolfmaster579
PostSubject: Re: Asking the pros before I commit (front coil springs)   Asking the pros before I commit (front coil springs) EmptyMon Jun 13, 2016 3:25 pm
Thanks. Yeah, I just want to be safe. They were rated for the reattas, caddy seville, and olds trofeo. Those codes were different loads. They read me off the RPO codes that would match. They had numbers in them. So long as they work. smile should be safe. Not like im racin the old girl.
» The optimal spring floor for Judo, or What goes under the tatami?
» I got a note today in the mail from Minelab re a possible fault in the Mono coil that comes with the 5000
» To Diff drop or not to Diff drop.....that is my question....
» coil id with out markings
» Which coil!
