| | How do the mice get in? | |
+21Karma stan word deekster_caddy woggy ibmoses ewolfe0050 Chicken T Riley Rickw albertj 95RiviSC Ash robotennis61 AA 97Riv-Jon jax95riv Andysdorm SpaceBar Mr.Riviera Jack the R 25 posters | |
| Subject: Re: How do the mice get in? Fri Sep 24, 2010 11:26 pm | |
| I just picked up on this topic... Are the mice generally getting into cars parked outside or inside? If it's inside, I would suggest that if you think you might have the little suckers around, a good "preventive measure" would be to fire up an un-catalyzed lawn-mower, etc, and let it run in the enclosed space for, oh, a full tank. | |
| | | Jack the R Master
| Subject: Re: How do the mice get in? Sat Sep 25, 2010 1:04 am | |
| - Eldo wrote:
- I just picked up on this topic... Are the mice generally getting into cars parked outside or inside?
If it's inside, I would suggest that if you think you might have the little suckers around, a good "preventive measure" would be to fire up an un-catalyzed lawn-mower, etc, and let it run in the enclosed space for, oh, a full tank. Both, but more mice in the garage. The garage isn't closed off enough yet to keep the carbon monoxide in or the outside mice out. | |
| | | Rickw Guru
| Subject: Re: How do the mice get in? Sat Sep 25, 2010 1:42 am | |
| - Jack the R wrote:
- Both, but more mice in the garage.
The garage isn't closed off enough yet to keep the carbon monoxide in or the outside mice out. I thought all your efforts this summer were to get the garage sealed up. I thought you were close at the beginning of the season. Must have misunderstood. Ah, we did have an unusually HOT summer. That would have slowed me down on the garage work. Hell, I didn't accomplish shit this summer myself. I hope you eventually get the best of those bastards. I hate mice with a passion. I also hate cats, but if I had that problem, I would have one hungry cat living in the garage. I'd feed it breakfast only and then let it fend for itself for any snacks it might find. Might let it in on special occasions, but that would depend on how nasty the cat turned out to be. I certainly couldn't live with a cat in the house full time. Not Me. Good luck JR and thanks for the pic's of the various ventilation doors or whatever they are called on the Riv. Would never have known thay were there if weren't for your dogged attention to get the damn mice. Just like Bill Murray in CaddyShack. Change the Golfers for mice and get some sensitive detonation devices. Kill All The Golfers. No Gophers, Golfers, whatever - they are all useless. | |
| | | Eldo Expert
| Subject: Re: How do the mice get in? Sat Sep 25, 2010 2:48 am | |
| To condense what Rick said: I didn't know about the trunk-type vent in the RF wheel well either...
And I'm so anal retentive that ExLax has me on their Christmas list! (Though to be fair, I lost my lift/alignment rack 8 years ago, during the Eldorado years...) | |
| | | Jack the R Master
| Subject: Re: How do the mice get in? Sat Sep 25, 2010 4:50 am | |
| Rick - I did work on the garage to seal it up in early spring, but once it warmed up enough for finishes to dry I switched over to the doors for the house, and have been on them ever since.
The garage uses rough finished oak siding and it will take a ton of work to get it sealed. I've made great progress, but there's still so, so far to go to keep mice out.
Eldo - There's also a vent in the driver's side front wheel well.
Hell, maybe we'd better check the driver's side rear well too because GM put mouse doors in ALL the others. | |
| | | albertj Master
| | | | albertj Master
| Subject: Re: How do the mice get in? Sat Sep 25, 2010 7:50 am | |
| - Jack the R wrote:
- Rick - I did work on the garage to seal it up in early spring, but once it warmed up enough for finishes to dry I switched over to the doors for the house, and have been on them ever since.
Hell, maybe we'd better check the driver's side rear well too because GM put mouse doors in ALL the others. For your own peace of mind you should check but I think when you pull up the carpet on drivers side trunk you will find a plastic plug swaged or cemented in place where the corresponding vent is on the passenger side. Albertj | |
| | | Jack the R Master
| Subject: Re: How do the mice get in? Sat Sep 25, 2010 5:40 pm | |
| The plug idea is a bust The inside of the plenum isn't flush with the opening, so the plug falls inside. edit ------------------ I wired a bigger piece of mesh to the plug, so it can't fall in. This works, but I'm not sure one of our stout country mouses can't dislodge it. There's not much for the plug to grab on. I'll try another plug design. What's really needed is a piece of mesh bigger than the opening on the inside and outside, wired together. There's not much room to work in there with the strut in place. This sure would be a good job to do when changing struts. | |
| | | Sponsored content
| Subject: Re: How do the mice get in? | |
