 Driver Seat Removal
3 posters
RivGuy
Driver Seat Removal Empty
PostSubject: Driver Seat Removal   Driver Seat Removal EmptyMon Aug 01, 2016 3:51 pm
How do you remove drivers seat to replace seat adjustment switch ?
RivGuy
PostSubject: Driver seat removal   Driver Seat Removal EmptyMon Aug 01, 2016 4:18 pm
On previous post I forgot to mention seat will only go forward once forward no way to get it back, can the seat be removed or at least get up and out of way to replace switch?
Thank you
PostSubject: Re: Driver Seat Removal   Driver Seat Removal EmptyTue Aug 02, 2016 2:47 am
You need a Torx socket I think it's a 45 or 50 size. just remove the bolts and remove seat.But I think the switch is behind the small side panel along the drivers side.
RivGuy
PostSubject: Drivers seat removal #3   Driver Seat Removal EmptyTue Aug 02, 2016 10:52 am
I know how to unbolt the seat, the problem will be getting the seat to go
backward, it only goes forward !
Can it be hot wired ( jumped ) so it can be powered to go back ?
Hoping someone out there can help.
Thanks
Rivlanta
Rivlanta
PostSubject: Re: Driver Seat Removal   Driver Seat Removal EmptyWed Aug 03, 2016 5:35 am
Hey RivGuy...A year or so ago I swapped-out all my seats. In the process, I had to disassemble the driver's seat switch and "manually" move the seat using a separate 12V Power Supply unit.
You may want to take a look at my write-up (page 3 of https://rivperformance.editboard.com/t3059p50-write-up-front-rear-seat-removal) as I explained how to move the seat manually as well as swap-out the seat switch. Let me know if you have specific questions and perhaps I can help.
RivGuy
PostSubject: Drivers seat removal #3 or 4   Driver Seat Removal EmptyThu Aug 04, 2016 10:58 am
Craig, I have reviewed your post, I have the car battery power ,OK, but my problem is I have a used switch (seller said good ) from a 95 not sure of condition or, if a 95 vs a 96 ( my car is a 96 ) is adaptable. So if I run seat full forward and new switch does not work, how do I get seat back so car is drivable again ? So my real question is very basic terms how can I hot wire, jump, to manually move seat forward and backward ? Car is OK to drive now just a bit tight.
Bob
Rivlanta
Rivlanta
PostSubject: Re: Driver Seat Removal   Driver Seat Removal EmptyThu Aug 04, 2016 4:26 pm
Bob,
I do not have the schematics for a '96. However, I can tell you that when I purchased the '95 seats for my '97, the seat adjuster switch and wiring harness were different so I am thinking you may not be able to use the '95 switch you bought without doing some difficult re-wiring. (I am not sure on this since I don't have the '96 Service information.)
Regardless, I would definitely not recommend trying to hot-wire/jumper anything within the switch. The simple reason is your switch connects to a multi-wire connector and a MEMORY SEAT/MIRROR CONTROL MODULE--not simple connections to get the 12V to where it needs to go. You could easily damage the Module and other circuit devices.
Lastly, my only suggestion, is that if you are familiar with electrical circuit troubleshooting, there are extensive troubleshooting steps in the Riviera Service Manual for diagnosing a seat that only moves one direction. Again, I only have the '97 Service Manual; but even with my electronics background, these procedures looked a bit daunting!
Also, take a look under the seat to see if there are any obvious problems (e.g., connectors not tight, broken or chafed wires, something stored beneath the seat obstructing movement or pinching wires).
Sorry I don't have better news. Maybe a '96 owner out there can be of some help.
Driver Seat Removal
» Driver's seat
» 95 riv seat switch removal
» Seat Removal and Airbags
» Write-Up: Front/Rear Seat Removal
» Front seat removal
