| Trunk Striker | |
tloukaitis Amateur
Name : Terry Joined : 2016-03-01 Post Count : 27 Merit : 0
| Subject: Trunk Striker Wed Jun 29, 2016 12:31 am | |
| Anyone have any idea where I can get one of these? GM part #25649592. Includes pop up spring assembly.
Thanks, Terry | |
| Subject: Re: Trunk Striker Wed Jun 29, 2016 12:35 am | |
| sales@MoradPartsCompany.com
216-671-3736
Tell them Rob sent you.They don't know me from Adam but what the hey | |
Lmck3 Amateur
Name : Lance Mckinley Location : ft lauderdale Joined : 2013-10-03 Post Count : 47 Merit : 8
| Subject: Re: Trunk Striker Fri Jul 01, 2016 10:44 am | |
| i am going to the you-pull-it junkyard today to retrieve an airconditioning hose from my own wrecked 95 riv. if you wish, i can get you the trunk release part. for a riv bbs guy, i will unbolt what you need. pls advise,
tloukaitis Amateur
| Subject: Re: Trunk Striker Fri Jul 01, 2016 12:10 pm | |
| That would be great, Lance! Let me know, & I'll PayPal what you need. I have Morad sending me one, but I could use a spare; I have 3 '95's.
Thanks, Terry | |
Lmck3 Amateur
| Subject: Re: Trunk Striker Wed Jul 27, 2016 4:44 pm | |
| dont know what i was thinking. i very well knew my 95 riv was rear-ended which sprung the trunk-lid. it never shut again. the hold-down is sprung .25" sideways, the piece is not useable .and. it is not worth the postage.
tloukaitis Amateur
| Subject: Re: Trunk Striker Wed Jul 27, 2016 4:51 pm | |
| If you can get it, I'd still pay for it & the postage. All I really need is the shaft, which goes into the spring, with the rubber on the end.
Thanks, Terry | |
R1V 1T UP Enthusiast
Name : Timothy Location : Buffalo Joined : 2009-02-05 Post Count : 104 Merit : 0
| Subject: Re: Trunk Striker Wed Feb 21, 2018 8:46 am | |
| Hey there, not sure if you're still looking for this but I have a '97 that I'm removing parts from to another '97. If I can get it out you can have it if you're still looking that is.
While we're at it, I'm looking for information on how to remove the trunk lid without messing up the wiring. Does anyone know if the wire has a disconnect somewhere that doesn't require cutting? | |
| Subject: Re: Trunk Striker Wed Feb 21, 2018 9:45 am | |
| - R1V 1T UP wrote:
- Hey there, not sure if you're still looking for this but I have a '97 that I'm removing parts from to another '97. If I can get it out you can have it if you're still looking that is.
While we're at it, I'm looking for information on how to remove the trunk lid without messing up the wiring. Does anyone know if the wire has a disconnect somewhere that doesn't require cutting? If the stainless wheel arches on the 97 you are scrapping are available PM me. | |
| Subject: Re: Trunk Striker Wed Feb 21, 2018 10:03 am | |
| Subject: Re: Trunk Striker Wed Feb 21, 2018 10:23 pm | |
| - R1V 1T UP wrote:
- Stainless wheel?
The silver metal band with thin black rubber strip that covers the lip of each wheel opening. | |
| Subject: Re: Trunk Striker Wed Feb 21, 2018 10:40 pm | |
| Ah okay. I will take a pic of them and DM you. Should be relatively soon; depends on if I love going to work early in the morning. In the meantime, do you have an idea on how to disconnect the trunk wiring for a lid swap? | |
| Subject: Re: Trunk Striker Thu Feb 22, 2018 10:51 pm | |
| - R1V 1T UP wrote:
- Ah okay. I will take a pic of them and DM you. Should be relatively soon; depends on if I love going to work early in the morning. In the meantime, do you have an idea on how to disconnect the trunk wiring for a lid swap?
Trace the wires from the trunk lid backward to find the connector, I think it is under the package shelf. The connector for the CHMSL is behind the rear seat on the passenger side of the car. Not sure if there is a 'master' connect point for the tail lights and the antenna. | |
| Subject: Re: Trunk Striker | |
| Trunk Striker | |
