 Removing the passenger air bag
aquarius
PostSubject: Removing the passenger air bag   Fri Aug 26, 2016 8:07 am
Has anyone ever removed the passenger side air bag? If so, what bolts hold it into the dash?
Merit : 135
PostSubject: Re: Removing the passenger air bag   Thu Nov 03, 2016 3:28 pm
You will need an FSM.
PostSubject: Re: Removing the passenger air bag   Thu Nov 03, 2016 7:28 pm
You have to take apart the dash and the glove box. It bolts in, but before you do any of that, you have to disable the system, and the procedure for that is in the FSM.
» Removing scratches from Windshield
» Removing Cork From A Rod
» POSSIBLE BROKEN PASSENGER AXLE SHAFT
» Help with removing gold from quartz
» Removing Ball Joints on a Polaris Sportsman
