| Write-Up: Riv Dash and Door Removal | |
+30stan Animator jbeganny Sir Psycho Sexy joshuadalegrimes matt270avian rivparadise th3fr4nchi5e RidzRiv Jimdangello rob97 96RIVMANN NelsonRiv dartcars LARRY70GS 2000ws6transam deekster_caddy DEMonte1997 Rickw IBx1 sburch23 1998 Riv albertj 99Rivman SuperRiv07 98riv Shintsu KillaKeninaRiv AA Jack the R 34 posters |
| Subject: Write-Up: Riv Dash and Door Removal Fri Jul 13, 2007 1:32 am | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Jul 13, 2007 11:14 am | |
| _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^
KillaKeninaRiv Addict
Name : Kenneth Age : 41 Location : Roseville, MI Joined : 2008-05-17 Post Count : 709 Merit : 6
| Subject: Re: Write-Up: Riv Dash and Door Removal Mon Jun 23, 2008 7:19 pm | |
| question: the previous owner of my car simply pulled the entire dash, the big peice off, and it broke off almost all of the plastic clips that hold it down along it except the bigger main ones so it looks stupid now. if i replace the dash, will the new one have the clips or were they part of the main dash that connects the dash to the actual frame underneath? | |
Shintsu Expert
| Subject: Re: Write-Up: Riv Dash and Door Removal Mon Jun 23, 2008 7:40 pm | |
| You have to do all that just to replace the radio? | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Mon Jun 23, 2008 9:01 pm | |
| - KillaKeninaRiv wrote:
- question: the previous owner of my car simply pulled the entire dash, the big peice off, and it broke off almost all of the plastic clips that hold it down along it except the bigger main ones so it looks stupid now.
Surely no one is that stupid and it was a radio thief who tore the dash up. I think there will be pieces in the dash itself that are busted. I've got no idea how well this would work but I've been seeing plastic welding kits in either the Eastwood or Harbor Freight catalogs. | |
Shintsu Expert
| Subject: Re: Write-Up: Riv Dash and Door Removal Mon Jun 23, 2008 9:29 pm | |
| I thought Harbor Freight went out of business? All the stores in my area closed up and there were several of them. | |
98riv Moderator
| Subject: Re: Write-Up: Riv Dash and Door Removal Mon Jun 23, 2008 10:57 pm | |
| - Shintsu wrote:
- I thought Harbor Freight went out of business? All the stores in my area closed up and there were several of them.
Nope still in business. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Write-Up: Riv Dash and Door Removal Tue Jun 24, 2008 12:31 am | |
| I got some stuff from them a couple days ago. The thing I wanted most is on backorder though :/ | |
Shintsu Expert
| Subject: Re: Write-Up: Riv Dash and Door Removal Tue Jun 24, 2008 4:12 am | |
| That sucks, I guess they just went out of business at all the local stores here. They had two or three and they all closed at the same time. | |
SuperRiv07 Addict
Name : Nick Age : 39 Location : Brookfield, And If everything goes right A Nice big house in Bolingbrook with a big GARAGE Joined : 2008-07-20 Post Count : 706 Merit : 0
| Subject: Quick Question? Fri Sep 19, 2008 11:47 am | |
| I want to pull out the dash panel that goes around the gauges and then it looks like it flows in to the door to a point i know the das panel comes off but do the lil panels on door come off? | |
99Rivman Aficionado
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 12:04 pm | |
| They do come off of the door panel, but with a lot of difficulty! With the door panel removed you can see the tabs from that panel on the inside, they are actually melted or hot glued in or something of that nature. I'm sure they can be removed, I have never done it, but you would have to hot glue them back in or something like that. | |
SuperRiv07 Addict
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 12:05 pm | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 2:59 pm | |
| Why do you want the dash panels off?
SuperRiv07 Addict
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 3:11 pm | |
| Im Gonna sand them down prime them and then go with a high gloss black and then clear coat the shit out of it just to add some caracter to my interior | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 4:21 pm | |
| I added character to my gray interior by repainting the ash tray covers in the rear. Went with a charcoal metallic, looks very nice. Ok ok, I was just covering up peeling paint on the lids... but it DOES look good! | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 5:08 pm | |
| Oh.
Some folks get woodgrain appliques. If I remember right they are available in black and colors too - but don't recall who from. Maybe search this editboard for links?
SuperRiv07 Addict
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 5:32 pm | |
| Yeah I really dont like the wood grian and Im Pretty handy so doining it myself will be fun | |
sburch23 Addict
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 8:10 pm | |
| Do you have woodgrain on those panels now? | |
SuperRiv07 Addict
| Subject: Re: Write-Up: Riv Dash and Door Removal Fri Sep 19, 2008 8:37 pm | |
| just around the radio and gear shifter | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Sat Sep 20, 2008 10:02 am | |
| My point was you could get black or whatever to replace/instead of the woodgrain.
The factory wood around shifter and radio is real, although it's an almost paper-thin layer of wood with a with thick layer of polyurethane over the top. When these are repaired sometimes they are replaced with fake wood.
SuperRiv07 Addict
| Subject: Re: Write-Up: Riv Dash and Door Removal Sat Sep 20, 2008 11:02 am | |
| well everything is getting blacked out | |
IBx1 Expert
| Subject: Re: Write-Up: Riv Dash and Door Removal Sun Nov 22, 2009 12:22 pm | |
| If I go extra slowly, extra carefully, and use these pictures as a reference to where the plastic things are, do you think I could remove the panels without breaking anything, or is it just inevitable? | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Sun Nov 22, 2009 12:33 pm | |
| I think you surely could do it without breaking stuff. Study the instructions (and posts in this thread) before you start, then read them one step at a time as you proceed, of if you get stuck. Be very, very gentle. Don't force anything unless you are sure it's free. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
IBx1 Expert
| Subject: Re: Write-Up: Riv Dash and Door Removal Sun Nov 22, 2009 1:48 pm | |
| It seems simple enough but once I get to the wiring behind the radio that's where it'll get confusing, fast. I will have harnesses and stuff and can usually figure things out, but if there's something that's completely different then I'm screwed until I find out how it's supposed to work. | |
| Subject: Re: Write-Up: Riv Dash and Door Removal Sun Nov 22, 2009 5:06 pm | |
| - IBx1 wrote:
- It seems simple enough but once I get to the wiring behind the radio that's where it'll get confusing, fast. I will have harnesses and stuff and can usually figure things out, but if there's something that's completely different then I'm screwed until I find out how it's supposed to work.
Then, your better off budgeting to pay someone else to do it for you. Especially if your time to do the job is limited to school breaks and cold weather. | |
| Subject: Re: Write-Up: Riv Dash and Door Removal | |
