 Weird light fluctuation...
2 posters
Hukmut
Merit : -2
Weird light fluctuation... Empty
PostSubject: Weird light fluctuation...   Weird light fluctuation... EmptySat Aug 27, 2016 10:21 pm
Hi folks! On my just acquired '98, the trans indicator (the display that shows which gear) indicates that the trans is in drive. It also flashes like it is on a flasher circuit. Usually goes off after 3 or 4 times.
Also, the odometer display will go off and on as well,but sorta independent.
My temp gauge worked for a while, now it does not.
Ok. I already know that I have electrical issues. No reminders, please. bonk
Now, how do I fix this stuff? In other words, where to start to fix it? Any and all help will be greatly appreciated. Thanks!
Merit : 180
PostSubject: Re: Weird light fluctuation...   Weird light fluctuation... EmptySun Aug 28, 2016 12:22 am
See if the instrument cluster wiring harness is loose.
Hukmut
Merit : -2
PostSubject: Re: Weird light fluctuation...   Weird light fluctuation... EmptySun Aug 28, 2016 8:36 am
Will do asap and you for the info!
Merit : 180
PostSubject: Re: Weird light fluctuation...   Weird light fluctuation... EmptySun Aug 28, 2016 11:28 pm
The other thing to look for is damaged wiring or switch on the transmission itself. On the S10 the Park/Neutral switch gets splashed if the guards are removed -- it's only a matter of time then before it dies. You will need a factory service manual I think. Check eBay.
» Battery light, airbag light, trans hung up in high gear, then dead.... Alte
» seat belt light / chime ? .... security light
» SES Light and then Oil Prrssure and Battery Light?
» alt light on changed batt alt and pcm light still on
» FAQ: Anti-Lock Brakes and/or Traction Control Light/Lamp On
