| How can I get the ABS/Traction Contol system to give codes? | |
+3IFallsRon Abaddon Dagwood(TSRW) 7 posters |
Dagwood(TSRW) Amateur
Name : Ted Location : Lake Lanier Joined : 2015-05-15 Post Count : 36 Merit : 3
| Subject: How can I get the ABS/Traction Contol system to give codes? Wed Oct 12, 2016 8:00 am | |
| My 1999 Riv ABS/Traction Control system light is on and I have no ABS. The brakes still function but I would like my ABS back. Most things I am seeing are telling me the system can provide codes if you have the right tool (GM Tech II). My Actron code reader doesn't read ABS codes. Is there any way to get the codes without the GM tool? I suspect a wheel sensor is bad but I need means of confirmation...
Dagwood RIDES: 1999 Riviera, no mods 2007 Mercedes Benz C63 AMG 1967 Oldsmobile Cutlass Conv. w/heavily modified 455, 5sp tremic 1973 SAAB Sonett III | |
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Wed Oct 12, 2016 8:19 am | |
| You need something "better" than a generic code reader. You can buy one that's a step up from it that reads ABS, and will also show live data. They aren't cheap though. They're around $300 for an "entry level" name-brand advanced scan tool.
Harbor Freight has a cheapy that reads ABS http://www.harborfreight.com/can-obd-ii-scan-tool-with-abs-60794.html | |
IFallsRon Fanatic
Name : R.L. Joined : 2012-11-23 Post Count : 268 Merit : 2
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Wed Oct 12, 2016 8:22 am | |
| My scanner locked up and same thing for free parts store scan. My best advice is start by checking each sensor.
Search "traction" on this site. There's plenty of threads. | |
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Sun Jan 01, 2017 8:48 am | |
| I just had this happen to me. ABS/Traction Ctrl light on after a minute upon start up. Had my friend with Tech2 scan it. Right side front sensor bad. No bearing noise at all. replaced front hub bearing with Timken bearing. Got lucky, was made in U.S.A. from Rockauto for 85.00. Actually ordered 2 bearings. The other was made in South Korea. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
71stagegs Enthusiast
Name : steve Age : 71 Location : L.I NY Joined : 2008-03-09 Post Count : 189 Merit : 2
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Mon Jan 02, 2017 10:38 pm | |
| USA USA keep that riv going Wizard | |
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 03, 2017 4:07 pm | |
| - 71stagegs wrote:
- USA USA keep that riv going Wizard
I'm doing my best Steve, LOL. Paint still looks awesome. Hope it stays that way. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 03, 2017 7:05 pm | |
brettfavreisamonster Amateur
Name : Huynh Location : LB, CA Joined : 2014-01-17 Post Count : 25 Merit : 0
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 17, 2017 2:48 am | |
| - LARRY70GS wrote:
- I just had this happen to me. ABS/Traction Ctrl light on after a minute upon start up. Had my friend with Tech2 scan it. Right side front sensor bad. No bearing noise at all. replaced front hub bearing with Timken bearing. Got lucky, was made in U.S.A. from Rockauto for 85.00. Actually ordered 2 bearings. The other was made in South Korea.
You ordered 2 and 1 is usa and the other is south korean? | |
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 17, 2017 8:24 am | |
| - brettfavreisamonster wrote:
You ordered 2 and 1 is usa and the other is south korean? Yes, one had made in USA on the box, AND stamped into the part itself. The other said made in south Korea on the box, nothing on the part. They both looked the same. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
makemann1 Member
Name : Max Location : Northville, MI Joined : 2012-11-16 Post Count : 66 Merit : 5
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 17, 2017 1:08 pm | |
Can you provide part numbers for these items? Thanks. | |
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 17, 2017 1:30 pm | |
| - makemann1 wrote:
Can you provide part numbers for these items? Thanks. Sure, Timken 513121. http://www.rockauto.com/en/moreinfo.php?pk=1117671&cc=1303322&jsn=436 The same part for 1999 Riviera. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
makemann1 Member
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? Tue Jan 17, 2017 1:33 pm | |
The same part for 1999 Riviera. Perfect! Thank you. | |
| Subject: Re: How can I get the ABS/Traction Contol system to give codes? | |
