| Subject: Re: Tick tick tick Sat Nov 19, 2016 12:22 pm | |
| The difference with the thermistor, that's a Riviera-specific item. The battery cable you bought was not Riv-specific. Technically it's the wrong part, even if it "fits".
The pulley is a universal application and should be standardized to fit any 3800 SC engine using that tensioner. Rock Auto sells the AC Delco tensioners, advertising them as "GM Original Equipment". If you buy these (the correct ones), the OEM pulleys will swap. If you buy a cheaper aftermarket version, it's a case of getting what you pay for. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
