| exterior mirror glass | |
95riviboy93 Rookie
Name : Eric Location : chicago il joliet il Joined : 2016-01-18 Post Count : 16 Merit : 0
| Subject: exterior mirror glass Fri Aug 12, 2016 3:52 pm | |
| There's a beehive behind my passenger side mirror . How do I remove the mirror without breaking anything? | |
| Subject: Re: exterior mirror glass Fri Aug 12, 2016 5:42 pm | |
98riv Moderator
| Subject: Re: exterior mirror glass Sat Aug 13, 2016 9:27 am | |
| - 95riviboy93 wrote:
- There's a beehive behind my passenger side mirror . How do I remove the mirror without breaking anything?
Pull it straight out and it will pop out. It won't be easy, but it will pop off. Make sure you grab on both ends of the mirror and pull straight out and not on an angle. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
95riviboy93 Rookie
| Subject: Re: exterior mirror glass Sun Aug 14, 2016 2:58 am | |
98riv Moderator
| Subject: Re: exterior mirror glass Sun Aug 14, 2016 7:23 pm | |
| One more thing. Depending on your options you may have some wires plugged in the back of the mirror so be careful with those. Take your time and it should come off. I would also wear some gloves to be safe. _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
95riviboy93 Rookie
| Subject: Re: exterior mirror glass Sun Aug 14, 2016 8:29 pm | |
EyeDoc1 Enthusiast
Name : Christen Location : Vancouver, WA Joined : 2016-03-30 Post Count : 125 Merit : 5
| Subject: Re: exterior mirror glass Tue Aug 16, 2016 12:56 am | |
| You might want to shoot some bee/wasp spray (on sale, large can, $2.99 at Ace Hardware) to kill critters behind the mirror. You'll have 2 or 4 wires ON the mirror, depending if it's just a heated mirror or the electro-luminescent variety (and I acknowledge probably using the wrong term). Search the forums about how to re-mount the mirror because it's a power mirror, and mine isn't working correctly. I need a weekend to get the manual out to make sure everything is lined up for remounting. I substituted a mirror from an Olds Aurora when my fancy one gave up the ghost. Junkyards are my best friends. | |
| Subject: Re: exterior mirror glass Tue Aug 16, 2016 10:17 am | |
| - EyeDoc1 wrote:
- You might want to shoot some bee/wasp spray (on sale, large can, $2.99 at Ace Hardware) to kill critters behind the mirror. You'll have 2 or 4 wires ON the mirror, depending if it's just a heated mirror or the electro-luminescent variety (and I acknowledge probably using the wrong term). Search the forums about how to re-mount the mirror because it's a power mirror, and mine isn't working correctly. I need a weekend to get the manual out to make sure everything is lined up for remounting. I substituted a mirror from an Olds Aurora when my fancy one gave up the ghost. Junkyards are my best friends.
I pulled a mirror blank off an Aurora some time ago - the one I got had heat but no auto-dim, although it was tinted gray. Yours? Albertj | |
95riviboy93 Rookie
| Subject: Re: exterior mirror glass Thu Nov 10, 2016 10:42 pm | |
| They are clear non heated | |
| Subject: Re: exterior mirror glass | |
