 96 riv no start, injectors not pulsing. Not PCM.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Wed Mar 29, 2017 8:48 am
I've been trying to track down the short with a multimeter. Replaced the maf hot line (pink 439) from the maf plug to the harness. Still low v at sensor with harness plugged in. Harness unplugged shows continuity and 9v at the same pin. Car running the fuse shows same .01 v as the sensor. Fuse internally had melted and refused(no pun intended).
Looks like I'm onto something just need to find the draw/short.
I agree.
Times I've had an electrical gremlin in my Riv have been times I worked on the electrics, even the cigarette lighter connections, without disconnecting the battery. Nowadays when I go in for any electrical work other than maybe a bulb change, I pull the battery cables. I dislike doing that because I don't want to scratch the rear seat leather. However, I dislike the gremlins even more. For work just under the hood often disconnecting the battery at the under-hood power point would be enough. However, it's also a good time to inspect and clean the terminals and main ground, so neutral I just pull the thing.
Merit : 238
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Wed Mar 29, 2017 12:45 pm
Hi Matthew. I agree this doesn't seem like a VATS issue. To rule it out, have you swapped in a 2nd PCM module? Running with MAF disconnected can cause rough idling, even stalling. Have you ruled out the MAF sensor as the problem? You mentioned disconnecting IAC valve made a difference. Have you considered replacing this part?
'98 SC Riviera • 268k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30
'05 GTO • 49k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Wed Mar 29, 2017 2:06 pm
I have replaced the Ckp, PCM, BCM and did a VATS bypass so far. None have fixed my problem.
I have unplugged both the IAC and the MAF and the car will run on the bonneville OSID (runs on VE tune). With both sensors unplugged the riv OSID the car will just crank and never fire up. Stalls sometimes with the IAC unplugged, but run the same MAF or no MAF with that tune.
I think the MAF fuse i replaced last night blew immediately when key was turned to on. So i most definitely have a short somewhere post IP fuse box, and its the pink MAF power wire because that was completely replaced from the sensor to the harness as close as i could cut it and crimp in a connector.
Im betting whatever it is shorting out to is what is causing the no-start with the riv OSID and the start with the bonneville OSID because the bonneville pcm wire setup is slightly different. For example maybe its looking for MAF g/s on wire 17 and the riv maf is wire 54. But the riv wire 17 is coolant temp so it sees a number for Maf and is ok to start.
1996 with 244k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Thu Mar 30, 2017 10:17 am
Just throwing this out there... I've been watching this thread so far but haven't had anything to offer.
This is purely anecdotal, since I just went through something sort of the same and I know people like to see their own solution in other kind of similar problems, but it might be something to rule out. I feel like albertj was on the right track at the ignition switch. There is a whole bunch of stuff that actually runs through there for the car to run and stay running besides jumping to VATs. At the end of the lock tumbler at the left of the steering wheel is a rotating switch barrel with quite a number of engine-running critical wires that get switched on when the key is turned on. The key rotates through the steering column and in turn rotates this barrel switching mechanism. In my case, the screws holding that switching thing onto the steering column were getting loose, causing *some* of the many connections that go through it to intermittently loose connection. This caused a host of really random symptoms/starting problems/running problems/etc.. It was random but I only got pointed at it when I found the car would run with the steering wheel tilted all the way up but would die if I tiled it down. I'm not saying your issue is exactly the same, but it might be something to investigate as something might be crossing/shorting or just not quite making connection in there. Perhaps the bonnie tune doesn't do some of the checks through the ignition switch tumbler as the riv does?
Also will the 96 not start without the maf connected? My 98 could, but I haven't tried on my 96. The 95 for sure won't due to a lack of a MAP.
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Thu Mar 30, 2017 10:29 am
Thank Karma. Yes my car always would start with no MAF, even with the LQ4 MAF i currently have.
If i am unable to find the break in the maf wire i will pull the column apart and inspect the lock mechanism. I could only see 1 wire (really 2 white wires) coming out of there and that read the resistance of the key. When measured with key on it read the same as the key.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Thu Mar 30, 2017 12:34 pm
Actually I have to thank one of the techs at an undisclosed GM dealer who mentioned to me that Riv used a very similar ignition switch to those subject to recall but in his personal opinion wasn't listed in the recall because too few Rivs were made. The cars in that particular recall are not the only ones with gremlin-infested ig switches; the Riv supposedly uses an ig switch similar to that in the S10 (I think same switch different pinout in the rectangular connector), and they are not problem-free.  My problem at the time was a sort of random stall/no restart. We put noids in parallel with the injectors and added jumpers so i could see them under the back edge of the hood.  When the car stalled i recorded the state of the noids. That was how we found it the first time.  A couple of the gearheads (gearhead is a term of endearment, folks) at the dealership had come up with how to connect the NOID lights so as to disclose the problem.  Not all the NOIDs were attached to the injectors.  Anyway - when I reported the pattern (by cellphone while waiting for a tow) they knew right away it was the ig switch.
The second time, I had put about  another ~100,000 miles on the car and it started acting up.  I'd have to check my log as to what was wrong, but I do recall I replaced the switch again to fix that.  I think it was a no-reason VATS no-start or some such silliness.
This time (just a few months ago) after yet another 100,000 miles I noticed my ig switch was doing weird things, for instance, if I pressed on it with no key in the warning chime would fire... and I could not turn the key to the Accessory position any more.  It was also putting the car into the VATS no-start, at first intermittently but as time went on, more often.  My elderly dad insisted it was the starter that was busted, I humored him and replaced it (its not terribly difficult nor expensive on the Riv) and that did not fix anything.  I was planning a steering wheel swap anyway (mine was chewed and I got a nice deal on a NOS unit) so I had the ig switch and keyway (and turn signal switch) replaced as part of that maintenance.  WHAM, the VATS no-start and the chime problem vanished, and of course I could turn to ACC again.
It was those experiences and the knowledge that a number of systems rely on the ig switch working that I suggested you check  it.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Thu Mar 30, 2017 12:57 pm
Those two little wires are for the key part. The whole lock tumbler goes through the steering wheel and this(bottom left of pic) gets turned with the key:
http://www.rockauto.com/info/301/D1482D_Primary.jpg
It attaches to the left of the column and the other end down at the floor.
18 wires in there.
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Fri Mar 31, 2017 12:48 pm
Is there a way to test that or am i dropping $130 on a hope that it fixes it.
I know for sure that i have no V at my MAF sensor and no V at the fuse (fuse is good) with the connector plugged in, so i either have 2 separate issues that came up at the same time, or that device controls power to the MAF and injectors with key on.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Fri Mar 31, 2017 3:45 pm
I think you could unplug it at the floor and use a multi-meter to test continuity on all the pins with the key turned... They should each have contact in at least one of the 3 active key positions(on, start, and accessory) depending on what they are. You could also check from the + line at the MAF to the firewall/floor connection just to see if it goes there. I can see later this weekend if my FSM from the 96 lists what the wires are if you want?
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Fri Mar 31, 2017 4:06 pm
I have a FSM and its the pink 439 (C2) wire on the connector. When i checked the other day it had ~9V to it. Not sure if its supposed to have 12+ or not but FSM says maf connector should be 5-7V on the troubleshooting part for the P0102 code
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Fri Mar 31, 2017 9:19 pm
A few posts ago you mentioned a short that was blowing a fuse.
Before you replace the ig switch, suggest you fix that short asap.  However, they could be related and the ig switches do wear out.  Have to see a wiring diagram on that one. Would not be alarmed if coincidentally both problems obtained.
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Mon Apr 03, 2017 11:43 am
Tore into the harness again this weekend. 12V+ at the fuse for MAf, nothing at the firewall pin C2.
So i ran a direct wire to the 12V lead for the EGR, since i dont have one of those.
Voila, I have a MAF again. CEL went off and the car runs better. Plugged in the riv tune and no start still!
Maybe whatever wire the MAF shorted with is keeping the car from starting but i sure as hell cant locate it behind that firewall plug.
I did notice with the bonny tune and the MAF working i still have low boost (5lbs WOT 5krpm) I also only see 5* of timing at that same time so maybe im bleeding off all the boost through the valves. No idea why my timing would be so messed up. Could the sensor wire that shorted be the cam or crank sensor? I would think without those i would have misfires and or a poor running condition/CEL.
I am going to look at the bonny tune again, maybe it didnt copy something over right from the riv tune.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Mon Apr 03, 2017 3:58 pm
why don't you have an EGR?
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Mon Apr 03, 2017 4:02 pm
Stage 4 weight reduction.
Actually the pipe for it developed a hole a long time ago and i just got rid of the system. Plus the intercooler stay cleaner with no EGR and no PCV (just breather).
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Mon Apr 03, 2017 6:14 pm
So your tune is set up to fake/eliminate the EGR check?
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Mon Apr 03, 2017 8:59 pm
Yes the code is removed, same for the cat.
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Sun May 07, 2017 3:51 pm
Swapped out the ignition switch with one from a low mileage riv. Still will not start with the riv pcm.
Edit: something else i discovered...The bonny tune is for a L36 car, not L67. The PCM numbers are the same so the 256k storage and hardware will be the same but the software is different which is likely why the car runs poopy even with my L67 files copied over.
When i tried to start the car with the original riv PCM i noticed the CEL doesnt do its startup check. Going to try to reflash a riv file to the "good" PCM again. Even though the "bad" pcm with the bonny file did start the car.
Merit : 99
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Sun May 21, 2017 3:19 pm
Swapped files and pcms around a couple times and every time it will do the CEL self check and car will crank with the l36 files. Nada with the l67 riv files. WTF is going on with my car? I'm out of parts to replace.
Merit : 122
PostSubject: Re: 96 riv no start, injectors not pulsing. Not PCM.   Mon May 22, 2017 4:30 pm
...any way to compare the L36 to the L67 startup sequence? Anybody?
» Bike will not start (fuel injector, fuel pump, HALL)
» Another 'no start' condition (SOLVED - new injectors)
» 1999 riviera sc3.8 no start, help!!
» no Start-k100
» 1984 k100 won't start.
