 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Mon Sep 25, 2017 8:18 pm
Tried to rewire to what I thought was right and now I see 1.3 vac all the time so must have made a sing the wire order. None of the colors line up with the connector. Will have to try again tomorrow.
Edit: looks like I rewired it correctly. Ground goes to evap, 5v on pin A, and sensor wire goes to connect as it should. Even tested a 1.5v AA battery to the signal wire and the car read -4psi as expected.
So maybe the map got fried being plugged in wrong? Anyone have a used MAP sensor they want to sell?
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Mon Oct 02, 2017 8:05 am
Got a used MAP from Morad and same thing. CEL and -0.5psi all the time.
Merit : 137
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Mon Oct 02, 2017 12:22 pm
Think the map sensor was wired wrong. Testing 5v on center wire and think it should be on end
Is this (MAP wiring) still an issue?
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Mon Oct 02, 2017 12:52 pm
I show ground connects with car ground, 5V on A (red wire) and dk green center wire goes to the D1 terminal on harness connector and registers change on scan tool when going through the pcm.
Merit : 137
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Tue Oct 03, 2017 5:03 pm
do you have this info about MAP sensors?
http://aemelectronics.com/?q=forum/map-sensor-reading
The only *other* thing I learned is, if there is a fault in teh wiring to the MAP sensor, it will kill the sensor pretty much the moment you plug it in. Also, thinking about it, maybe the ECU is damaged. I don't know.
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Mon Oct 09, 2017 9:28 am
When MAP is plugged in the voltage drops to 1.7V so explains why the PCM always sees close to 0psi. Also looks like I still have it wired wrong and maybe it was wired correctly to being with but the V drop was my problem.
Seems the EGR and A/C pressure sensor is also connected to the same 5v circuit from the PCM. guess im tracing more wires this week.
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Thu Oct 12, 2017 2:18 pm
Ran the 5v from my EGR plug to the map and the car is fixed. Not sure where the 5v map wire is shorted or half broken but I don't really care since I have no EGR anyways.
Thanks to all that helped me the past few months with these wire issues. Nice to have the car running like it should again! 3gears
Merit : 137
PostSubject: Re: 96 riv no start, injectors not pulsing. fixed w/wire harness +new issue   Thu Oct 12, 2017 5:32 pm
...pat yourself on the back.
» Brisbane Track Class 11/02/11 Start Lists
» TRACKING OR FIXED ON A GPX
» False start rule causes problems when applied sporadically
» Paris Diamond League - July 8th Provisional START LISTS
» False start rule makes athletes edgy for USA Champs
