 Underbody
95riviboy93
Underbody Empty
PostSubject: Underbody   Underbody EmptyTue Mar 21, 2017 8:40 pm
What do you guys use as protection for the underside of your 8th gen?
Merit : 152
Underbody Empty
PostSubject: Re: Underbody   Underbody EmptyWed Mar 22, 2017 8:56 am
Primarily, rinse it so dirt does not hold moisture on it. .
Secondarily, if rust emerges, clean it with wire brush then naval jelly or some such, and then treat it with POR 15 or Rust Bullet, which scavenges the oxygen out of the residue of the corrosion and leaves a solid finish. When dry topcoat that with undercoating.
Be sure the battery is properly vented or else the acid fumes *will* eat a hole in the floor under the back seat in 12-18 months (some list members found that one out the hard way).
Finally, don't get the insides (too) wet. Cabin moisture, unchecked, will combine with the dirt and will eat it from the inside out. If you have sunroof, then you have sunroof drains and you need to be sure they are connected and they are not clogged. There's other posts about that on this site.
95riviboy93
Underbody Empty
PostSubject: Re: Underbody   Underbody EmptyWed Mar 22, 2017 10:14 am
Thanks albert unfortunately when i bought my rivi two years ago it already had a small hole under the battery
Merit : 152
Underbody Empty
PostSubject: Re: Underbody   Underbody EmptyWed Mar 22, 2017 2:31 pm
What kind of hole? There is supposed to be a hole there with a grommet in it that the battery vent tube passes thru.
95riviboy93
Underbody Empty
PostSubject: Re: Underbody   Underbody EmptySat Mar 25, 2017 4:04 pm
A Rust hole. the vent tube is where its suppose to be its just damaged up where it forms the rectangle. I wish i knew how to post pics here
Underbody Empty
Underbody
» Chevrolet 6.5 litre in Patrol
