 Windshield Washer System
98RivOwner
PostSubject: Windshield Washer System   Sat May 13, 2017 9:07 pm
Dr
I noticed mine quit spraying on the windshield a few days back. Coul hear pump but no spray action. I noticed liquid stain underneath RF wheel well after I attempted an actuation in the driveway. Opened the hood and did see anything abnormal.
I assumed I had a broken hose inside fenderwell, took plastic shield off and broke several chrome trim clips in the process 😣
Everything looked good, then I remembered you coul actuate the washer function and it would spray long enough for me to get back under the hood for an inspection while it was in service.
Found a hose broken at a connection just prior to the firewall entrypoint. Hose/plastic is very brittle, will need to replace.
Are these 5/32 ID?
Anyone replaced these before?
https://goo.gl/photos/WmjtNYdU2cmQmUbV9
Merit : 135
PostSubject: Re: Windshield Washer System   Fri Feb 09, 2018 12:48 pm
98RivOwner wrote:
Dr
Are these 5/32 ID?
The cowl grille for the 1998 riv comes with washer lines and nozzles complete with the funnel-looking boot for the firewall pass-thru but gmpartsdirect.com does not show it as available any more. The diagram shows the firewall passthru and that funnel looking boot. Part is "25649744 Cowl Grille." This site shows the part available but I am not sure I believe it: https://www.oemautopartsandaccessories.com/catalog/parts/view/n/cowl-grille-25649744/v/buick-riviera-1998/vtec/182674/pid/ee9a2c70a53cc057/ They say they sell dealer stock, so they *might* actually have the things. This info should give you the starting point to use their site to find the part that is under the hood (not under the cowl, that's what I listed).
If the fittings/washer nozzles are not brittle, you can reuse them if you can get the hose off without too much fuss. If you need pointers on working with the stiff plastic hose (usually nylon) let us (me) know.
98RivOwner
PostSubject: Re: Windshield Washer System   Tue Feb 13, 2018 7:42 pm
Thanks Albertj, I've managed to tape my old one up enough to partially function, still get leakage under the hood when I actuate the pump.
Just received notification that a 97 Riv has arrived at a PYP nearby will investigate this possibility.
Thanks again
Mark
» What point system for a fun Playoff Pool here?
» GP3000 & Extreme - Updating the Battery System
» Forumotion ranking system.
» Cleaning carbs/ other parts with a parts washer?
» Trinity Racing full exhaust system plus more parts for sale
Riviera Performance ::   General Tech :: Engine Bay-
