 Coolant over flow
9ty7rivi
PostSubject: Coolant over flow   Sat May 20, 2017 3:37 pm
Probably a weird question but, does anyone know where I could possibly get a coolant overflow cap? Can't find one for the life of me!
Lmck3
PostSubject: Re: Coolant over flow   Mon May 22, 2017 2:12 am
the pull-a-part junkyard crawl might be your best solution.
[ while you are at it, a spare junkyard reservior for $15 is good insurance,
because our plastic riviera coolant tanks are living in a harsh envirement
and they are made of an element in the periodic table named "Unobtanium" ]
the gm part number for the cap appears to be 25635870, which is discontinued.
they show up on eBay occasionally.
this plastic cap fits many older gm vehicles.
here is a partial list from GM Parts Direct:
       1993 Buick Roadmaster Limited 5.7L V8 - Gas
       1993 Buick Roadmaster Base 5.7L V8 - Gas
       1993 Buick Roadmaster Estate Wagon 5.7L V8 - Gas
       1992 Buick Roadmaster Base 5.7L V8 - Gas
       1992 Cadillac Allante Base 4.5L V8 - Gas
       1992 Cadillac Allante Value Leader 4.5L V8 - Gas
       1995 Cadillac DeVille Base 4.9L V8 - Gas
       1994 Cadillac DeVille Base 4.9L V8 - Gas
       1993 Cadillac Eldorado Base 4.9L V8 - Gas
       1992 Cadillac Eldorado Base 4.9L V8 - Gas
       1992 Cadillac Eldorado Touring 4.9L V8 - Gas
       1993 Cadillac Fleetwood Base 5.7L V8 - Gas
       1993 Cadillac Fleetwood Brougham 5.7L V8 - Gas
       1993 Cadillac Seville Base 4.9L V8 - Gas
       1993 Cadillac Seville STS 4.6L V8 - Gas
       1993 Chevrolet Caprice Classic 5.0L V8 - Gas
       1993 Chevrolet Caprice Classic LS 5.0L V8 - Gas
       1993 Chevrolet Caprice Classic LTZ 5.7L V8 - Gas
       1993 Chevrolet Caprice Classic 4.3L V6 - Gas
i have a spare reservior cap with a broken retainer ring.  you can have it as a temporary fix.
9ty7rivi
PostSubject: Re: Coolant over flow   Mon May 22, 2017 12:02 pm
Yes, I have crossed referenced those parts from my local auto part store, and I can assure you that they are totally different. For some reason they are smaller than the one I need and also made of rubber instead of plastic. If you would like to sell that cap I would be more than willing too purchase it! I have a rag stuffed in there at the moment nono and I just don't like the way it looks plus, quote me if i'm wrong but, from what I remember that tank is pressurized.
PostSubject: Re: Coolant over flow   Mon May 22, 2017 3:37 pm
Lmck3
PostSubject: Re: Coolant over flow   Mon May 22, 2017 4:25 pm
update:
i discovered a good-condition cap for the 8th gen riv's plastic coolant reservoir.
you can have it no charge.
send your address by private message.
the reservoir is not pressurized.
the radiator cap allows excess coolant (caused by expansion of liquid when hot)
to flow into the plastic tank.  then, whenever  the engine is turned off long enough to
cool down, mr. vacuum and the radiator cap together allow coolant from the plastic reservoir
to be drawn back into the radiator, thus topping off the closed cooling system.
9ty7rivi
PostSubject: Re: Coolant over flow   Mon May 22, 2017 7:19 pm
Thanks a lot! Putting my Rivi back to top shape and the little things count! bounce
9ty7rivi
PostSubject: Re: Coolant over flow   Mon May 22, 2017 7:21 pm
Thanks for the link anyway Larry70GS. I couldn't for the life of me find one locally and I have a GM store(DELCO supplier) here in town.
Lmck3
PostSubject: Re: Coolant over flow   Tue May 23, 2017 2:41 pm
to
9ty7rivi,
if you want me to give you a correct reservoir cap,
you will need to send me your address via
the "Messages" button at the top of the screen.
Coolant over flow
