 1995 alternator wireing harness
JacobsRedRivi
1995 alternator wireing harness Empty
PostSubject: 1995 alternator wireing harness   1995 alternator wireing harness EmptyTue May 30, 2017 10:48 am
Hey for whatever reason my electrical connector just crumbled into pieces. Does anyone know where i can buy a replacment?
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyTue May 30, 2017 4:47 pm
JacobsRedRivi
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyThu Jun 01, 2017 2:12 pm
Looks like that but mine has only 2 wires in the back of the connector.   95 rivi
I may be wrong though. I will double check when i get to the house.
JacobsRedRivi
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyFri Jun 02, 2017 10:55 am
Ok so it is only a 2 wire harness. A green wire and a red wire. 2 leads. Any idea where i could get that connector?
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyFri Jun 02, 2017 11:23 am
JacobsRedRivi
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyFri Jun 02, 2017 11:47 am
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyFri Jun 02, 2017 12:41 pm
Can't imagine why that is unless someone put a different alternator on there. If Rockauto doesn't have it, I'd say you have a problem unless you can match something up at a parts store.
JacobsRedRivi
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyFri Jun 02, 2017 4:24 pm
Ill look into it and post back. It was defiantly the OEM Alternator when i bought it.
Does the harness just give information to the PCM or does it control the charging?
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptySat Jun 03, 2017 8:28 am
What difference does that make? You need it for proper alternator operation. You may be able to substitute generic crimp on connections.
JacobsRedRivi
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptySat Jun 03, 2017 5:04 pm
Just cuerious. But its definatly a 2 wire connector. I cant figure out how to upload pics from phone. If i get a 4 wire connector could i just splice the cables i need?
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptySat Jun 03, 2017 6:52 pm
Doubtful. The connector can't be the same with 4 wires. You can't post pictures on this board, you have to upload them to a host like photobucket, then link them.
JacobsRedRivi
PostSubject: Re: 1995 alternator wireing harness   1995 alternator wireing harness EmptyTue Jun 06, 2017 2:15 pm
I was able to just splice the two wires that i needed. They were labled S F L P and the origional connector had the same but tge wires were just S and L. So i spliced those and were all good!
» Naish Waist harness
» 4 point harness
» Harness and Bar.
» Sick of your inadequate Minelab Harness ? Look here.
» Prototype of new combo belt harness for Minelab GPX's
