 Part # for interior door lights?
RivieraRyan
Part # for interior door lights? Empty
PostSubject: Part # for interior door lights?   Part # for interior door lights? EmptyTue May 30, 2017 7:02 pm
My lights inside the door have blown on the plaatic handle and the one above the metal handle. What ate the part #s so i can order them? Also I need a red courtesy light on the right drivers door as well, mechanic cracked it. Any help is much appreciated.
Merit : 153
PostSubject: Re: Part # for interior door lights?   Part # for interior door lights? EmptyTue May 30, 2017 7:09 pm
Those have been unobtainable for a long time. Several years ago I posted a note on how to repair them, but I can't find it. Maybe one of the moderators can point it out.
Basically, you can pull the wires out, pull the blue lens off the respective assembly, replace the bulb with a "grain of wheat" bulb, insulate the leads with silicone gasket maker (black or clear) paint it turquoise (get the paint from a craft store) if you need to or pop the blue lens back on, and reinstall it.
I've repaired mine more than once. It takes a little time but it is no big deal.
PostSubject: Re: Part # for interior door lights?   Part # for interior door lights? EmptyTue May 30, 2017 7:26 pm
KenBluder
KenBluder
PostSubject: Re: Part # for interior door lights?   Part # for interior door lights? EmptyFri Aug 18, 2017 7:53 pm
The red marker light is no longer available new and almost impossible to find used. I discovered that GM 10247755 used in 1997 - 2003 Grand Prix's will work perfectly. I have a spare if you need one.
I have been helped so much by this board, email me at kenmb1061@gmail.com and I'll send it to you at no charge. I bought a pair and installed one in the driver's door with no problem.
» LED Dome Lights
» Cabelas Door Buster Sale ~ Garmin 60CSX $199
» which part of toronto is grass roots canada located?
» HID lights
» What have you done to your SidexSide this week?
