 Sway bar installation
Sway bar installation Empty
PostSubject: Sway bar installation   Sway bar installation EmptyThu Jun 29, 2017 3:06 pm
So... I got a '99 Seville rear antisway bar to install on my Riv (it's the same as the STS bar).  My old bar broke (it outlived 3 pairs of links, I installed Moog Problem Solvers and.. oopsie... good bye bar end). The new bar looks about 1-2mm thicker than the old. For you GM gearheads, the old bar is "green" and the new is "yellow."
I wrapped the working segments of the bar (where the bushings ride) in teflon tape coated with a paste I made of tune-up grease (polysiloxane) and graphite, and over-wrapped the ends with amalgamating tape. I assume the teflon will wear through in a while. We'll see how the rest of it lasts.
PostSubject: Re: Sway bar installation   Sway bar installation EmptyThu Aug 17, 2017 1:15 am
Follow-up: the wrap, i removed. The bushings. Kind of soaked up the silicone. I got the ride improvement one would expect. When i replace shocks i will probably also install a set of GM springs, which are variable rate (now - they didn't use to be).
9ty7rivi
PostSubject: Re: Sway bar installation   Sway bar installation EmptyThu Aug 17, 2017 7:49 am
Does that make the ride feel firmer?
PostSubject: Re: Sway bar installation   Sway bar installation EmptyThu Aug 17, 2017 9:39 am
Variable rate springs get firmer the more they compress. The "normal" ride quality is still there, but the car will feel stiffer when going over larger bumps and turning corners.
PostSubject: Re: Sway bar installation   Sway bar installation EmptyThu Aug 17, 2017 7:54 pm
I am still on original springs after 340,000 miles and expect that i should replace them, finally. The VR springs cost a bit more than standard rate but not crazy.
» Rhino rear sway bar removal
» Teryx sway bar
» RZR-S Rear Sway Bar
» Broke sway bar on RZR S
» Rear Sway Bar Delete on RZR-S
