 Blinking Temp
Yardley
Blinking Temp Empty
PostSubject: Blinking Temp   Blinking Temp EmptyWed Jul 05, 2017 7:05 am
The digital readout on my AC/outside temp blinks for about a minute when I start the car. It is a '96 Riv. Also, while that is happening there is a rhythmic squeaking sound coming from behind the center of the dash, like an air door is trying to seal or move.
Any ideas? Normal for a 96?
http://www.1badriv.com
stydel311
Blinking Temp Empty
PostSubject: Re: Blinking Temp   Blinking Temp EmptyThu Jul 06, 2017 11:02 pm
The blinking indicates there is a fault in the climate control system, what you are hearing is probably that fault. One of the blend door motors is most likely failing.
IFallsRon
Blinking Temp Empty
PostSubject: Re: Blinking Temp   Blinking Temp EmptySat Jul 08, 2017 3:54 pm
The blinking and noise started this week with my 97. The noise started when the temp was warm enough for me to turn down to the lowest setting. If I move the temp from 60 to 65, the noise goes away. The blinking generally stops after a few seconds when the gauge adjust for ambient outdoor temperature.
stydel311
Blinking Temp Empty
PostSubject: Re: Blinking Temp   Blinking Temp EmptySat Jul 08, 2017 11:56 pm
Are you using the climate control on automatic? I leave mine set to 70 most of the time and usually only touch the vent button to run the ac compressor or not.  When the flashing stops is normal, I believe it only flashes for 60 seconds to indicate that there is a trouble code and then goes to normal operation.
IFallsRon
Blinking Temp Empty
PostSubject: Re: Blinking Temp   Blinking Temp EmptySun Jul 09, 2017 8:11 am
I use auto for AC but mostly it is in the off position. When I hit auto, the system goes rock and roll until I can manage temp and fan speed.
Merit : 153
Blinking Temp Empty
PostSubject: Re: Blinking Temp   Blinking Temp EmptyMon Jul 10, 2017 8:59 am
Is this normal, hmmmmm....?
When I am  trying to figure out if something is normal or not, I think to myself, "if I was buying this car new and it did this during a test drive, would I still consider buying it?"
PS: I think this climate control issue is def one for the factory service manual.  I dimly recall some sort of HVAC-self-test-calibration action in the FSM but I don't think this is it.
Blinking Temp Empty
Blinking Temp
» Water Temp Gauge
» POlaris rear lights blinking?
» Temp light on when engine is cold??
» Players In-Out/Temp Loan Spells
» Dc 40 blinking odd and red at same time as blue.
