 Trunk Lift Supports
2 posters
Merit : 149
Trunk Lift Supports Empty
PostSubject: Trunk Lift Supports   Trunk Lift Supports EmptyTue Oct 31, 2017 2:22 pm
Anyone replaced the gas charged lift supports in their trunk? Looks like they just pry off on each end?
9ty7rivi
PostSubject: Re: Trunk Lift Supports   Trunk Lift Supports EmptyTue Oct 31, 2017 5:16 pm
Once I get home I will take a look into the service man and get right back at ya! currently 4:16 here in texas. Im usually home by about 5-5:30.
Merit : 149
PostSubject: Re: Trunk Lift Supports   Trunk Lift Supports EmptyTue Oct 31, 2017 6:20 pm
I looked in the manual to no avail. There are some things the FSM is good for and others it is not, this is one. I figured it out myself. Both ends push onto ball studs. To get the old ones off, there is a band clamp opposite the stud on the lift support. All you do is pry that clamp off with a small screwdriver, and it pulls right off easily. Installation is very easy, you just push them right on, the clamp expands and it pops on. They come with grease inside each end, so it is very easy. I bought the Monroe replacement lift supports on rockauto for 16.49 each.
http://www.rockauto.com/en/moreinfo.php?pk=61138&cc=1303322&jsn=402
9ty7rivi
PostSubject: Re: Trunk Lift Supports   Trunk Lift Supports EmptyTue Oct 31, 2017 6:33 pm
Glad you figured it out. Thanks for the info as I plan on replacing my rears. My front are starting to lose support also..I do pop it a lot though. Lol.
Trunk Lift Supports
» Front wheel hop (maybe) when I lift off accelerator.
» Dorman Window Lift Motor
» Air Lift 1000 Air Spring Helper Kit
» Trunk Leaks
» trunk latch
