 Oil Pressure Gauge Switch / Sensor
2 posters
Oil Pressure Gauge Switch / Sensor Empty
PostSubject: Oil Pressure Gauge Switch / Sensor   Oil Pressure Gauge Switch / Sensor EmptyWed Dec 27, 2017 8:21 am
Mine is leaking oil so i was going to rockauto to order another one, but I see several different part numbers from the same company, all different prices, but all for a 3800. Anybody know which one is "best".
FWIW I do have an L32 but i think the plate is bolts to is part of the filter housing so it would have come off my L67.
For 96 S/C Riv:
STANDARD MOTOR PRODUCTS PS270 {#25535479} OIL PRESSURE LIGHT SWITCH Info
w/ Light ??
$12.92
STANDARD MOTOR PRODUCTS PS246 {Click Info Button for Alternate/OEM Part Numbers} Info One of our most popular parts
w/ Gauge
$21.79
STANDARD MOTOR PRODUCTS PS615 {#19244518} Info
w/ Gauge
$22.79
For 05 GTP (L32)
STANDARD MOTOR PRODUCTS PS279 {Click Info Button for Alternate/OEM Part Numbers} OIL PRESSURE LIGHT SWITCH Info
w/ Light
$11.17
Oil Pressure Gauge Switch / Sensor Dsc_0110
PostSubject: Re: Oil Pressure Gauge Switch / Sensor   Oil Pressure Gauge Switch / Sensor EmptyWed Dec 27, 2017 8:26 am
Was able to answer part of my own question, the 05 GTP (L32) type sensor is 2 terminal, the rivs have 4 terminal connectors. SO PS279 will not work with a riv.
Also going to take a guess that since the riv has a dash light and not a dash gauge for oil pressure I should be going with the PS270 sensor.
Merit : 180
PostSubject: Re: Oil Pressure Gauge Switch / Sensor   Oil Pressure Gauge Switch / Sensor EmptyThu Dec 28, 2017 12:13 pm
Yep.
PostSubject: Re: Oil Pressure Gauge Switch / Sensor   Oil Pressure Gauge Switch / Sensor EmptyThu Dec 28, 2017 1:20 pm
Ended up getting one locally at o'rileys auto. BMD(?) brand. seems to have stopped my oil leak.
Thanks for the reply Albert.
» Write-Up: Fuel / Oil Pressure Sending & Gauges
» FAQ: Engine Coolant Temperature & Fan Turn-On
» Switch/sensor on back side of ac compressor
» FAQ: New Riviera Buyer Questions
