| Where is the A/C drain located? | |
+3BillBoost37 manofmany jdbell2004 7 posters |
jdbell2004 Amateur
Age : 38 Location : Iowa Joined : 2008-07-27 Post Count : 34 Merit : 0
| Subject: Where is the A/C drain located? Wed Aug 06, 2008 7:15 pm | |
| I cannot find it. There is water all over on the passenger side carpet. I don't see any pipes running through the firewall at all. Any ides where this thing is? | |
manofmany Addict
| Subject: Re: Where is the A/C drain located? Wed Aug 06, 2008 10:49 pm | |
| - jdbell2004 wrote:
- I cannot find it. There is water all over on the passenger side carpet. I don't see any pipes running through the firewall at all. Any ides where this thing is?
I'll try to get a peak tomorrow, but its most likely behind the kick panel on the right. | |
BillBoost37 Junkie
| Subject: Re: Where is the A/C drain located? Thu Aug 07, 2008 8:59 am | |
| You should be able to locate a hole from under the car to poke and get it draining.
Anyone ...where under the car do you see the drips? | |
Chicken Aficionado
| Subject: Re: Where is the A/C drain located? Thu Aug 07, 2008 9:05 am | |
jdbell2004 Amateur
| Subject: Re: Where is the A/C drain located? Fri Aug 08, 2008 11:00 am | |
| Chicken, this look familiar? I'll get you a pic of where it goes too. If you jack the car up, just behind the engine on the firewall you will see a half inch of hose sticking out of the firewall that the flange end of this piece fits over, beak facing down. Mine's pretty dirty so I assume that is why its leaking back into the car... | |
Chicken Aficionado
| Subject: Re: Where is the A/C drain located? Fri Aug 08, 2008 11:37 am | |
| HAHA Holy Crap!! What the hell is in there????
Pics would be great! Thanks! | |
jdbell2004 Amateur
Chicken Aficionado
| Subject: Re: Where is the A/C drain located? Fri Aug 08, 2008 2:08 pm | |
| Thanks for the pic.....so it just presses on? no retainer? no clamp? | |
jdbell2004 Amateur
| Subject: Re: Where is the A/C drain located? Fri Aug 08, 2008 4:57 pm | |
| Roger that, seems unsecure but thats how it was when i pulled it off. | |
Chicken Aficionado
| Subject: Re: Where is the A/C drain located? Fri Aug 08, 2008 5:50 pm | |
| huh... I wonder if my gauge install in the vent caused back pressure and blew this thing off.... | |
96RIVMANN Fanatic
Name : Paul Location : MN Joined : 2007-10-22 Post Count : 253 Merit : 11
| Subject: Re: Where is the A/C drain located? Fri Aug 08, 2008 7:27 pm | |
| You don't even need that rubber thing I would just pitch it. jdbell2004, I knew that was your problem. Good thing you got it fixed now pull that passenger seat and peel up the carpet and let it dry out! | |
Rivlanta Member
Name : Craig Location : Atlanta, GA Joined : 2009-07-19 Post Count : 60 Merit : 22
| Subject: Re: Where is the A/C drain located? Sun Feb 18, 2018 3:28 pm | |
| Hey all.
I am really missing seeing all the photographs, etc. since the Photo-posting debacle. Even my own posts seem to have lost their value.
Oh well...here's my request for help.
I am 99% certain that my Evaporator Drain Hose needs to be unplugged. I am getting some moisture inside on the Passenger side, and no condensation draining underneath when I run the AC.
I cannot find this crazy drain hose! I've read all the posts (less pics now), but still can't locate it. Here's what I know:
- It's on the Passenger side outside firewall. - You can't really see or access it from beneath the hood. - It must be accessed from beneath the vehicle. - It has a "duck-bill" termination on the end. - I've looked through my Service Manuals and they are of no help.
Can anyone please post (or send me a photo) of how I can see/get to this hose? I need to get it unplugged ASAP.
Thanks so much! | |
| Subject: Re: Where is the A/C drain located? Tue Feb 20, 2018 11:10 am | |
| - Rivlanta wrote:
- Hey all.
Thanks so much! Very quickly: The hose is conspicuous, if it is there, when you put the car on a lift or ramps and look under it on the lower right quadrant (lower part of passenger side of) the firewall. It looks a bit weird, you can't un-see it once you have seen it. It is rubber, sticks out horizontally about an inch tehn straight down. It is literally stuck on the firewall with an "O" shaped piece of 3M trim tape. When you get a new one, you peel the backing off and stick it on over the hole. So if the hose is missing you will see a round hole about 1.25 - 1.5 CM in diameter, in the firewall, the kind of thing you look at and say "how did that plug fall out?" Yeah it looks like a nondescript hole. You **NEED** the hose on for the drain to work right in most climates. For some reason it's not on the Riviera diagrams for the '98. For the Park Ave it is. Might want to ask a dealer if one is in the dealer network or in Vintage parts. They are discontinued but the PN for the Park Ave one I think is 25723079. The other thing - GM switched to a hose with a molded in nipple that snugs into the hole in the firewall, on many early 2000s US built models. A knowledgeable parts guy may be able to match up one for you that will fit the hole in the Riv firewall; if so would you post the P/N? Albertj | |
Rivlanta Member
| Subject: Re: Where is the A/C drain located? Wed Feb 21, 2018 2:52 pm | |
| Thanks, Albert.
I am going out now to see what I can find. | |
| Subject: Re: Where is the A/C drain located? Wed Feb 21, 2018 10:22 pm | |
| - Rivlanta wrote:
- Thanks, Albert.
I am going out now to see what I can find. ..and you found?!? | |
Rivlanta Member
| Subject: Re: Where is the A/C drain located? Thu Feb 22, 2018 5:50 pm | |
| Well, I did successfully locate the hose. It is old, but still functioning (draining water). I will continue looking for the cause of damp passenger side carpet.
Now, while driving home today, I have another problem that I need to research. Speedometer is erratic (sometimes at 0) and the transmission was slipping quite badly.
Always something with these old beauties. I am still trying to sell her, but now may end up donating her to a good charity. Depends on what I find with the transmission.
Thanks for your help Albert. I would not have found the hose without your guidance. | |
| Subject: Re: Where is the A/C drain located? Thu Feb 22, 2018 10:45 pm | |
| - Rivlanta wrote:
- Well, I did successfully locate the hose. It is old, but still functioning (draining water). I will continue looking for the cause of damp passenger side carpet.
Thanks for your help Albert. I would not have found the hose without your guidance. About the water, if your Riv has a sunroof, check the drains. You *may* have to pull the A-pillar trim to do this. I remember *years* ago a list member wrote about a water-on-the-floor problem and it turned out that for some reason the drain hose had come disconnected or some such. I could be wrong, though, and I am not sure how that'd happen, anyway. There's another couple-three reasons as well. Transmission slipping, first thing to check is the level and color of the fluid, I think. Speedo erratic, I'd have to look that up. Do you have the factory manual? | |
Rivlanta Member
| Subject: Re: Where is the A/C drain located? Fri Feb 23, 2018 4:09 am | |
| Okay...will check sunroof drains.
I am going to check for any codes, but what I have researched on the speedo/transmission problem is that it is likely the transmission speed sensor. It is located on the passenger side output of the transmission and costs around $45. Looks like it's fairly accessible with the front pass tire removed. I will let y'all know how the replacement goes. | |
Rivlanta Member
| Subject: Re: Where is the A/C drain located? Sun Feb 25, 2018 6:06 am | |
| Sunroof drains are working fine. So further exploration needed.
Speedo/Transmission was indeed a problem with the transmission speed sensor. The connector had come out of the sensor itself. Reconnected and all seems to be working again. However, 1st to 2nd seems a little more harsh, but I want to give the computer time to re-calibrate. | |
| Subject: Re: Where is the A/C drain located? | |
