srjen1 Member
Name : Stephen Location : Rochester, New York Joined : 2018-03-05 Post Count : 78 Merit : 2
| Subject: Any idea what this chip goes to ? Mon Mar 05, 2018 12:21 pm | |
| Bought a 95sc Riv a little while back only 31k for miles on it (see pic in welcome section today). Previous owner told me he had just changed the sc pully to a 2.5 inch. After running car I realized there was an air leak, (engine light on after idling for awhile) changed sc gasket and and is ok now. Reading posts on this site I checked plugs, original AC plugs, changed them to auto lite 605. Not sure if thermostat was changed but car runs 2 lines below 200. So I put the original 2.85 pully back on, car runs great. But I found this chip in the glove box, texted previous owner what this was, never heard back. I think i have the car back to stock, the radio was changed out , not sure if this chip has anything to do with the radio. Thanks | |
srjen1 Member
| Subject: Re: Any idea what this chip goes to ? Thu Mar 08, 2018 8:33 am | |
| Thanks to reading this site I see the 95 Riv has a prom chip that can be changed in the pcm, I thought the previous owner may have changed it with this chip with the sc pully. Looks like the pcm is a 28 pin chip, this is 24 so i'm not as worried about it. Love reading info here. | |
| Subject: Re: Any idea what this chip goes to ? Fri Mar 09, 2018 6:41 am | |
| Hello Stephen, As an OBD 2.0 owner, I had the same thought that you did. Also, I had a 1.0 car that took THIRTEEN chips before the factory got it 'right... allegedly.
However, I think we may be right with our guts. Check out this old Summit Racing listing's numbers: https://www.summitracing.com/parts/aaz-71-8026antt/overview/
Sure seems awfully similar, Mark | |
srjen1 Member
| Subject: Re: Any idea what this chip goes to ? Fri Mar 09, 2018 9:16 am | |
| Subject: Re: Any idea what this chip goes to ? Fri Mar 09, 2018 9:23 am | |
| You're very welcome... Let us know if I was actually right~ | |
srjen1 Member
| Subject: Re: Any idea what this chip goes to ? Fri Mar 09, 2018 9:32 am | |
| We got hit with a bunch of snow, car in the garage covered up. I might have to take a look at the chip thats in the car now. Not sure what the original # or letters should be on the chip for a 95sc Riv. I looked at that site, might try and send a question to them about that chip. | |
| Subject: Re: Any idea what this chip goes to ? | |
