 CASE relearn necessary or even possible on 95 SC?
CASE relearn necessary or even possible on 95 SC? Empty
PostSubject: CASE relearn necessary or even possible on 95 SC?   CASE relearn necessary or even possible on 95 SC? EmptyFri Apr 06, 2018 11:15 pm
I'm chasing some problems, one of which is the P0341 camshaft sensor DTC, and through many of the threads it is mentioned that a "CASE learn" or "CASE relearn" may be required if one changes the crank or camshaft sensors, or PCM.
I was wondering if a "CASE learn" was even possible for the 95 SC?
Thanks,
Merit : 155
PostSubject: Re: CASE relearn necessary or even possible on 95 SC?   CASE relearn necessary or even possible on 95 SC? EmptyTue Apr 10, 2018 12:47 pm
See http://rivperformance.editboard.com/t9010-crank-sensor-relearn -and- https://my.cardone.com/techdocs/PT%2070-77-0003.pdf
I'd check the wiring to the sensor for intermittents. Eliminate the simple stuff first. Kinda like keeping the mice out of the elephant pen, so the elephants don't stampede.
PostSubject: Re: CASE relearn necessary or even possible on 95 SC?   CASE relearn necessary or even possible on 95 SC? EmptyFri Apr 13, 2018 5:53 pm
Yep, am running down the wiring issue for the CAM sensor.
Just was wondering if any relearning was needed. I've already changed the PCM and swapped over the original ROMs a few years ago, and it never quite ran as good again. So just wondered if the CASE learn/relearn was even applicable to a 95 Series 1 SC.
Merit : 155
PostSubject: Re: CASE relearn necessary or even possible on 95 SC?   CASE relearn necessary or even possible on 95 SC? EmptySat Apr 14, 2018 3:29 pm
Let's ask Abaddon (hint hint)
» Transmission & gear-case fill, drain and oil
» Fox STR alarms and reciever in presentation case.
» Pelican i1015 case
» Rotozip with attachments and case
» Display case from Quantum Leap
