 Part # for drivers side inner tie rod?
3 posters
RivieraRyan
Part # for drivers side inner tie rod? Empty
PostSubject: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptyWed Apr 18, 2018 12:51 pm
Anyone know the part # for drivers side inner tie rod for a 1998?
Merit : 180
PostSubject: Re: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptyWed Apr 18, 2018 2:00 pm
Depends on whether internal or external threads on tie rod housing end
internal --> 26003751, 26021769, and I think moog EV195
External --> 15221006, 21011026, 26034348, moog EV260
PS these are right off of RockAuto.com
Not sure what the differences are, knowing GM it's just the supplier at the time of mfg.
Yours is almost certain to be external threads, but you should check first.
RivieraRyan
PostSubject: Re: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptyThu Apr 19, 2018 1:27 am
Do you have a link to that diagram with all the GM part#'s?
Merit : 180
PostSubject: Re: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptyThu Apr 19, 2018 10:39 am
No, but the software at the dealer does excepting the Moog numbers. The GM numbers can be seen on rockauto.com. They do not exactly list them for you, you have to deduce what they are by carefully reading the listings.
Alternatively, on gmpartsdirect.com you can see a diagram, the current GM number for the Riv [15221006] and current gmpartsdirect price [$80.57]. To get there you will need to use a web browser to look at gmpartsdirect.com, scroll down to the boxes under "3 Great Ways to Shop" and click the "Your Vehicle" box on the left to enter your particulars. The tie rods can be found under the Steering category.
Merit : 251
PostSubject: Re: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptyFri Apr 20, 2018 3:28 am
RivieraRyan
PostSubject: Re: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptySun Apr 22, 2018 12:22 pm
Thank you!!!
Merit : 180
PostSubject: Re: Part # for drivers side inner tie rod?   Part # for drivers side inner tie rod? EmptyMon Apr 23, 2018 8:38 am
» Part # for drivers side inner tie rod?
» FAQ: Warm/Hot Air on Drivers Side, Cold on Passenger Side
» A/C Colder One Side
» FAQ: Power Window Problems
» Drivers Side Window Misalignment
