| | Riv left me stranded today | |
| Subject: Riv left me stranded today Wed Apr 18, 2018 2:36 pm | |
| Was driving in stop and go rush hour traffic on the highway when I felt the engine skip a beat for the first time since I have owned it. It started to buck and stalled on me. Would not start and stay running, but it did start every time I cranked it, if only for a second. Thank G-d for AAA+ which got me home without too much fan fare. Went out this afternoon, and sat in the car, windows up. Cycled the ignition switch a few times. I could hear the fuel pump initiate for 3 seconds or so every time I cycled the ignition. Cranked it and it started right up and idled. Not trusting it, I let it idle for about 10 minutes. It then started to run rough, and it stalled. Wouldn't restart after that. I'm thinking the brand new Delphi pump I installed not more than a year ago took a dump on me. Gotta find my fuel pressure gauge, but I'm thinking it will be low. Anybody think of anything else? _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Abaddon Expert
| Subject: Re: Riv left me stranded today Wed Apr 18, 2018 2:42 pm | |
| Fuel Pressure gauge sounds like the right place to start. I've had pumps that ran, but wouldn't supply enough volume to keep the car running correctly. You can prime the rail (which you did by cycling the key), and it'll start, but there's not enough to keep it running. | |
| Subject: Re: Riv left me stranded today Wed Apr 18, 2018 3:48 pm | |
| - Abaddon wrote:
- Fuel Pressure gauge sounds like the right place to start. I've had pumps that ran, but wouldn't supply enough volume to keep the car running correctly. You can prime the rail (which you did by cycling the key), and it'll start, but there's not enough to keep it running.
Yes, that is what is happening. I'll confirm it when I dig out my pressure tester kit. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Riv left me stranded today Sun Apr 22, 2018 3:33 pm | |
| Well, it was a beautiful day, and I dug out the fuel pressure gauge. Started the car and let it idle. After about 5 minutes, the idle started to swing high and low and then it stalled. Fuel pressure was about 42 psi the entire time. Was able to start the engine and hold the throttle, and it would run smoothly, just would not idle, then it was perfectly fine for a few minutes, then stalled again. Called the director of my Buick club and he suggested I shut the engine and unhook the MAF sensor. That's what I did, and sure enough, the engine idled and ran fine. Let it sit there and idle for 1/2 hour and it never skipped a beat. I'm told to get an AC Delco MAF sensor, not anything else. Rockauto has them. Pretty pricey at 161.00. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Abaddon Expert
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 8:34 am | |
| Good call from the director. That's one of those things you can watch with a scan tool. The "estimated" g/sec and "actual" g/sec are probably off by about 3 grams.....
You can try cleaning it I suppose. | |
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 8:39 am | |
| That is my next step. Just have to get the right Torx security bit. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | albertj Master
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 8:41 am | |
| - Abaddon wrote:
- Good call from the director. That's one of those things you can watch with a scan tool. The "estimated" g/sec and "actual" g/sec are probably off by about 3 grams.....
You can try cleaning it I suppose. Also check for stuff like the air cleaner box cover isn't seated all the way. On mine I have to get the filter in just right then press firmly to seat it as the latches click. | |
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 3:33 pm | |
Also check for stuff like the air cleaner box cover isn't seated all the way. On mine I have to get the filter in just right then press firmly to seat it as the latches click. Actually, I am running the K&N filter. I check it periodically, but it always looks fine. I know if you use too much filter oil, it can foul the MAF wires. I have never re oiled it though. The box itself is definitely intact. Been driving the car with the MAF disconnected for now. Gonna try and clean mine first. If that doesn't work, I'll buy a replacement. My director tells me, AC Delco or Hitachi. Hitachi is less than half the price of the AC Delco on rockauto. https://www.rockauto.com/en/catalog/buick,1998,riviera,3.8l+v6+supercharged,1303322,exhaust+&+emission,mass+air+flow+sensor,5128 _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | AA Administrator
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 3:41 pm | |
| Larry, you can visually inspect the MAF elements. Use CRC electronic or other special MAF spray cleaner. I used to pull mine every year our so and give it a good shot. 281K+ on original MAF and counting...
Good luck with diagnosing this - at least you have it narrowed down! Hope there's just some crud in there that can be cleaned. Also inspect and wiggle the wiring and connectors!
_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 4:04 pm | |
| How about some brake clean? The only advice I got is not to spray it when the MAF is hot, do it with a cool part. Connector and wiring is mint. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | AA Administrator
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 4:09 pm | |
| I wouldn't, but it probably wont hurt it. I have the $7 can of CRC on the shelf just for MAFs and PCBs, so I reach for it. The key is a fast-drying spray with zero residue.
Good tip on waiting for it to cool, but it doesn't take long. The MAF is one of the cooler parts under the hood. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 5:21 pm | |
| Advance Auto has it in stock, so i will pick up a can tomorrow. it's amazing how those little wires can effect the engine like that. The idle was all over the place and the car was undriveable. As soon as I disconnected it, the engine ran fine. Driving it today, all I could notice was a momentary sag when getting on and off the throttle at speed, just barely noticeable. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | AA Administrator
| Subject: Re: Riv left me stranded today Mon Apr 23, 2018 6:07 pm | |
| Yeah, MAF is the main go-to reference for the PCM fuel tables. I think the way it works, if the MAF output doesn't jive, the PCM will use MAP as a back-up, but our cars have a typically bad MAP reference, so the car will buck and stall (I've been there) if MAF is bad.
Amazing is how these sensors function. A wire is heated, and the resistance of the wire is measured. The intake air moving past the wire cools it, changing the resistance. The output (MAFF) is a frequency from 2000kHz near idle to I think 12kHz at the top end, in 1kHz increments! Super precise and quick-acting, too!
| Subject: Re: Riv left me stranded today Tue Apr 24, 2018 11:37 am | |
| Well, cleaning it did no good at all. It didn't look dirty but was worth a shot. The plug is good, and all wires look good. It probably just went bad, after all, it is 20 years old. Gonna buy a new one. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | albertj Master
| Subject: Re: Riv left me stranded today Tue Apr 24, 2018 2:29 pm | |
| - LARRY70GS wrote:
- Well, it was a beautiful day, and I dug out the fuel pressure gauge. Started the car and let it idle. After about 5 minutes, the idle started to swing high and low and then it stalled. Fuel pressure was about 42 psi the entire time. Was able to start the engine and hold the throttle, and it would run smoothly, just would not idle, then it was perfectly fine for a few minutes, then stalled again. Called the director of my Buick club and he suggested I shut the engine and unhook the MAF sensor. That's what I did, and sure enough, the engine idled and ran fine. Let it sit there and idle for 1/2 hour and it never skipped a beat. I'm told to get an AC Delco MAF sensor, not anything else. Rockauto has them. Pretty pricey at 161.00.
Wait a minute -- did we check the IAC (idle air control) yet? And I forget when the last time was that you pulled the throttle body for cleaning. ...and here is a random, possibly useful LINK, from Delphi. | |
| Subject: Re: Riv left me stranded today Tue Apr 24, 2018 2:38 pm | |
| With the MAF disconnected, the idle is rock steady, actually pulls almost 21" of vacuum on my boost gauge. Connect the MAF, the engine goes rich, surges, and stalls. There was no check engine light on until I disconnected the MAF. If there was a wiring problem, reference, signal, or ground, I would have expected the SES light to be on as soon as the symptoms began. I will check them anyway. I'm sure the throttle body could use a cleaning. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | albertj Master
| Subject: Re: Riv left me stranded today Tue Apr 24, 2018 3:30 pm | |
| - LARRY70GS wrote:
- With the MAF disconnected, the idle is rock steady, actually pulls almost 21" of vacuum on my boost gauge. Connect the MAF, the engine goes rich, surges, and stalls. There was no check engine light on until I disconnected the MAF. If there was a wiring problem, reference, signal, or ground, I would have expected the SES light to be on as soon as the symptoms began. I will check them anyway. I'm sure the throttle body could use a cleaning.
My TB is due for cleaning, too, the tach flutters a little at idle. I do not think I will have the TB gasket soon, though (I am shopping for pats for this year's maintenance - have a bunch of things to tweek). In your case I think you're onto it with the MAF but I looked at old posts and didn't see any talk of the IAC so I figured I'd mention it... in hindsight I probably should not have. Albertj
| | | Abaddon Expert
| Subject: Re: Riv left me stranded today Wed Apr 25, 2018 8:20 am | |
| There's a 1 in a billion chance it's the wiring. For some reason, when MAF's go bad, 9 times out of ten they make the car run rich. If you had a diagnostic tool, you could watch it happen. It tells the PCM that it's taking in more air than it is, and so the PCM starts adding more fuel for it. The fuel trims shoot positive, and the car runs like balls.
On the older cars (like ours), it takes quite a while, or usually a complete wiring fault to set an SES light for this matter. Usually, it would set "lean" or "rich" codes before it would report the MAF as being bad. | |
| Subject: Re: Riv left me stranded today Wed Apr 25, 2018 11:20 am | |
| - Abaddon wrote:
- There's a 1 in a billion chance it's the wiring. For some reason, when MAF's go bad, 9 times out of ten they make the car run rich. If you had a diagnostic tool, you could watch it happen. It tells the PCM that it's taking in more air than it is, and so the PCM starts adding more fuel for it. The fuel trims shoot positive, and the car runs like balls.
On the older cars (like ours), it takes quite a while, or usually a complete wiring fault to set an SES light for this matter. Usually, it would set "lean" or "rich" codes before it would report the MAF as being bad. Yes, I saw that. My scan tool (old Auto X ray) has an operational monitor mode, I can see fuel trim, long term was almost -18. That fuel trim is super negative (that's rich, right?). I could smell the exhaust as well. Got a new MAF coming. Wiring looks good. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | Abaddon Expert
| Subject: Re: Riv left me stranded today Wed Apr 25, 2018 11:29 am | |
| - LARRY70GS wrote:
- Yes, I saw that. My scan tool (old Auto X ray) has an operational monitor mode, I can see fuel trim, long term was almost -18. That fuel trim is super negative (that's rich, right?). I could smell the exhaust as well. Got a new MAF coming. Wiring looks good.
Yep, that's rich. The MAF says more fuel, the PCM dumps it. Then the O2 starts reading rich (above 700mV), and the PCM then commands less fuel. Meanwhile, the TPS is just hanging out relaxing at idle. It turns into total computer confusion. Lather, rinse, repeat | |
| Subject: Re: Riv left me stranded today Wed Apr 25, 2018 2:23 pm | |
| - Abaddon wrote:
Yep, that's rich. The MAF says more fuel, the PCM dumps it. Then the O2 starts reading rich (above 700mV), and the PCM then commands less fuel. Meanwhile, the TPS is just hanging out relaxing at idle. It turns into total computer confusion. Lather, rinse, repeat You can say that again, never seen the engine convulse like that. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| | | albertj Master
| Subject: Re: Riv left me stranded today Thu Apr 26, 2018 11:06 am | |
| - LARRY70GS wrote:
You can say that again, never seen the engine convulse like that. We should name this "Spastic MAF Syndrome (rare)." | |
| Subject: Re: Riv left me stranded today Thu Apr 26, 2018 12:14 pm | |
| Spastic MAF syndrome leads to PCM Schizophrenia _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Riv left me stranded today Sat Apr 28, 2018 12:49 pm | |
| Installed the MAF along with a new Wix air filter. Started the car and it ran just like it always has, great. Cleared the MAF code and watched the sensor data. Everything looked good. For anyone else this happens to, get the Hitachi MAF. The director of my car club who works on cars all day told me, Hitachi or AC Delco. Interestingly enough, my original MAF had the numbers AFH50M-04 on it just like the AC Delco 2134338 https://www.rockauto.com/info/321/213-4338_Primary__ra_p.jpg
The Hitachi MAF0005 had the identical numbers on top. Take a look at the price difference, AC Delco, 160.99, Hitachi , 71.79, less than half. Same MAF.
| | | AA Administrator
| Subject: Re: Riv left me stranded today Sun Apr 29, 2018 10:26 am | |
| Glad you were able to sort this out, Larry. Too bad it was a failed part, but at least you found a decent deal on a quality part. Also good to see our forums active with troubleshooting advice again! _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Sponsored content
| Subject: Re: Riv left me stranded today | |
Similar topics | |
